Hi. I have more interesting findings based on the Monroney sticker. Let's go back to the Chevy Bolt example to explain these. Skip to Step 3 if you have read my previous message.
Step 1: Dyno tests
The first step of the process is to put the car on a dyno and do 2 tests. Here are Bolt's dyno scores once again:
City dyno score: 364.4 mi (
source)
Highway dyno range: 310.6 mi (
source)
Step 2: City, highway and combined range
The second step is to convert dyno scores to realistic range numbers because during the dyno test there is no air drag because the car doesn't move anywhere while it's on top of a dyno. To add the air drag effect, the dyno scores are multiplied by 0.7 if the car manufacturer doesn't bother calculating more realistic multipliers. That means we get these range numbers from dyno scores:
City range: 364.4 mi * 0.7= 255.1 mi
Highway range: 310.6 mi *0.7= 217.4 mi
The combined range is calculated by taking 55% of city range and 45% of highway range.
Combined range (EPA rated range): 255.1 mi *0.55 + 217.4 mi * 0.45= 140.305 + 97.83= 238.14
Step 3: Fuel economy
To calculate fuel economy, EPA assumes that 1 gallon of gasoline equals to 33.7 kWh (see the screenshot below). That means we need to find out how many miles per 33.7 kWh the car can drive. For this calculation, the city and highway range numbers in Step 2 and the recharge energy drawn from the wall outlet during the dyno tests will be used. The recharge energy numbers are from the same EPA file that shows the dyno scores.
Recharge energy after city dyno test= 67.42 kWh (
source)
City range : 364.4 mi * 0.7= 255.1 mi
Recharge energy after highway dyno test= 66.51 kWh (
source)
OK, so, we know that the city range is 255.1 miles and requires 67.42 kWh energy from the wall outlet. What would be the city range per 33.7 kWh (per gallon of gasoline equivalent)?
City fuel economy= 33.7 kWh/67.42 kWh * 255.1 mi city range= 127.5 miles per 33.7 kWh= 128 MPGe
Highway fuel economy = 33.7 kWh/66.51 kWh * 217.4 mi city range= 110.2 miles per 33.7 kWh = 110 MPGe
You can see the same two numbers on the EPA website
here. The MPGe numbers we just calculated and the numbers EPA published are a match. This confirms that we correctly identified how the fuel economy numbers are calculated. Here is a screenshot:
Model 3 80 (aka Model 3 LR RWD)
The question is, what does this tell us about the Model 3? We now have the MPGe numbers from the Monroney sticker and we have the dyno scores and energy consumption numbers from the EPA document and we know how the calculation works. So, let's reverse the calculation for the Model 3.
City fuel economy= 131 MPGe (
source)
Recharge energy after city dyno test= 89.4 (
source)
Highway fuel economy = 120 MPGe (
source)
Recharge energy after highway dyno test= 89.4 (
source)
If city range is 131 mi per 33.7 kWh recharge energy,
then city range is X mi per 89.4 kWh recharge energy.
City range= 131 mi * 89.4 kWh/33.7 kWh= 347.5 mi
Highway range= 120 mi * 89.4 kWh/33.7 kWh= 318.3 mi
Combined range (EPA rated range)= 347.5 mi * 0.55 + 318.3 mi * 0.45= 191.125+143.235= 334 miles
Conclusion:
Even when using the 0.7 multiplier that all EVs use, the Model 80 achieves 334 miles EPA rated range as suspected based on MPGe numbers on the Monroney sticker. For some reason, Tesla didn't like that and decided to voluntarily lower the range number like they have done many times. My guess is they want to continue selling more Model S cars while ramping up Model 3 production but if the Model 80 achieves 334 miles EPA rated range, the Model 80D would achieve 347 miles EPA rated range. That doesn't look good for the Model S 100D with 335 mi EPA, at least until they switch to the newer motors.
However, Tesla has never used the 0.7 multiplier for any Model S or X. The lowest they ever used was 0.733.
Here is a screenshot that shows the whole list. In other words, this appears to be a case of double sandbagging. First, they lowered the multiplier to 0.7 which is the default one every car maker uses. But that wasn't enough and they voluntarily lowered the EPA rated range.
This shouldn't be a surprise because Tesla has done the same thing to the Model S 7 times during the last 2 years to make the gap between S and X look smaller. Below is a screenshot from an actual EPA document which you can download
here. The file shows that the Model S P100D achieved 324 miles EPA rated range but Tesla voluntarily lowered it to 315 miles. I guess they didn't like the 324 miles number because the Model X P100D has 289 mi EPA and the gap would look too large. As a result, we have inconsistent EPA rated miles in different Tesla cars. 1 EPA rated mile in a Tesla should be equal to 1 EPA rated mile in another Tesla but it isn't.
