I'm not sure how useful the EPA ratings are, since those are submitted by the manufacturer and can and have been under reported. Tesla can rate their cars however they want to, as long as they don't inflate their ratings, like any other manufacturer, but the figures from the CSI report have to conform with EPA regulations.That's a reasonable argument when you look at the EPA rules but I don't think it's true. For example, the Model S P85D has its own EPA test and they used the 19" wheels. This example shows that Tesla can use the smaller wheels for range tests even if most sales of that model are with the larger wheels.
I can think of two counter arguments:
#1. Maybe less than a third of Model S P85D's are configured with 21" wheels.
#2. Maybe the P85D achieved 253 miles EPA rated range with 21" wheels.
#1 is unrealistic so I'm going to skip that. #2 is not true based on 3 data points:
1. In the footnote here says "In the table above all vehicles... " use 19" wheels.
2. If you read the blog post, it says that the 253 miles number will get a 3% hit with 21" wheels. Here is the relevant section:
3. The P85D initially had 242 miles EPA rated range (see the first screenshot). This was achieved using 21" wheels (see the second screenshot). However, then they changed it to 250 mi with 19" wheels and then to 253 miles.
I agree with you that according to the EPA rules, it should work how you have described it but I disagree that this is what actually happens. Here is the rule again:
Based on this, performance versions like the P85D and P100D should have the 21" factor accounted for in calculations but it doesn't appear to be the case. One counter argument at this point could be that maybe Tesla uses the voluntary reductions to make things right. Yes but in the last 2 years Tesla voluntarily lowered the EPA range of 7 different cars and all of them were Model S variants. None of them were Model X. In other words, they have been using voluntary reductions to reduce the gap between the S and X. Now they are using it for the Model 3 too.
The CSI report shows that Tesla used a road coefficient of 12.3 for the P85D and 11.9 for the 85D, which suggests they were using the 21" wheels for the P85D.
https://iaspub.epa.gov/otaqpub/display_file.jsp?docid=34294&flag=1
Last but not least, Tesla's application for the P85D explicitly states they're using the "worse case for emissions", and lists 21" wheels/tires.
https://iaspub.epa.gov/otaqpub/display_file.jsp?docid=34511&flag=1
Data Vehicle Selection Justification – This vehicle represents the 33% optioned test weight class, highest total road load, and highest N/V ratio that are expected to be the worst case for emissions.
Tires 245/35R21 (Front) 265/35R21 (Rear)
Tesla could be using the 18" wheels for the 3 LR, and we'll only know when the EPA publishes their application (or maybe the CSI report for the 3 SR), but my guess is the CSI report they submitted is with the 19" wheels.
