I can't remember, what are the measurements of brand new 18's? 10/32?
The MXM4s new are 8.5/32".
And what would be considered worn out?
I checked min last week. Car has 8,500 miles, rotated at 6,500 miles. Fronts are at 4.5mm, rears are at 5.5mm. Seems excessive to me - I'll be replacing tires at 15,000 miles!
I've since become more sensitive to acceleration and cornering to extend the tread. I also expect to file a treadwear warranty claim when I get new tires.
Apart from the first few weeks, no mashing the pedal from standstill. (229 lifetime wh/mi).
LR RWD, MXM4s currently at just under 7/32” all around. 15K miles, now rotated twice (rearward cross).
I guess having the car mostly in the hands of the conservative driver (wife) has its benefits. I play on weekends.
I drive pretty conservatively (~9K total miles at 220 wh/mi lifetime with several 500+ mile roadtrips) and am at 8/32 all around from my last service appointment a couple weeks ago when I was at 8900 miles. I've never rotated it since there's no point in doing it yet. How you drive must have a significant impact on tread wear.
Edit: This is for the LR RWD that I took delivery on in March 2018.
LR, RWD, 18” Aeros removed. I rotated mine at 5,000 miles. The OEM Michelin MXM4 have 8/32” new. My fronts were still 8/32” and rears were 7/32”.
My OEM tires on my 2010 Prius were Yokohama and I only got 26,000 miles out of them. I used Michelin Energy Savers after and got warranty miles every time.
I read on the Prius forum that OEM tires are not made to same specs as new replacement tires and typically do not have the same tread depth.
When the wear bars start showing/wearing even with the tread. That might be different for different tires...probably around 3/32”, typically 2/32” is considered “replace immediately.”. If you have a lot of wet weather pushing beyond 3/32” will probably give you noticeably less traction and your tire guy might start gently prodding for replacement.
Thanks, I’ve generally used wear bars. But I wanted to get a feeling how much wear folks were at from the prior posts. I rotate frequently and watch my pressure. And have not had much uneven wear and generally hit near the rated range of the tire for as long as I can remember. 20 years? I hope that continues with Model 3. But these posts are making me a little concerned. These tires are not cheap and contribute to the cost of ownership. Most cars have got at least 40k miles out of tires.
As much as I might have elected for Pilot Sports in the past, I doubt I'll be willing to take the mileage hit. I'm at 227 Wh/mi lifetime and suspect putting on the Pilots would knock that up to 250+ Wh/mi AND wear out faster! That's one great thing about ICE cars- they are so damn inefficient that you barely notice a hit in efficiency from tire compound!
Rotated tires recently on my RWD, the fronts look practically new compared to the rears which are almost at the wear bars after 7,000 miles. Heavy foot and I try to make regen do most of the work stopping. Stock 18 Michelins.
The tires might be terrible in the rain but they aren't cheap. The stock 18 tires are more expensive than the Pro Pilot.Yay, the sooner these eco-garbage tires wear out, the better!
Drove them in the rain for a few days last week, they are comically bad in the wet. I noticed today they carry the M+S mark, I can only imagine how entertaining they’d be in wet snow, especially with RWD.
Living in California, they aren't so bad. The added range is nice for the road trips I take.Yes, Tesla paid for being able to claim 310 miles and little else with these tires.
Here is an image of my front and back tires when I rotated them at the 6200 mile mark around 4 months of ownership. I do let the car loose from time to time. Also do 90 mph road trips. I guess it all adds up. I'm over 12k miles now. I don't think they will pass inspection when my 1 year comes around in May.
