It’s a big enough issue I won’t even use AP when it’s wet out anymore.
Didn’t think of that...
On the positive side, it was incredibly windy (gusts up to 50mph) and AP held its lane like a champ.
I just drive whatever feels comfortable when not on AP.Probably a good idea. Every single safety organization (weather service, highway patrol, etc.) continue to recommend not using cruise control in the rain. In spite of this poorly headlined clickbait Jalopnik article, it's very likely a bad idea to use it in poor conditions (as the article says!).
Let's Debunk The Idea That It's Not Safe To Use Cruise Control In The Rain
The main reason is that it can lead to loss of situational awareness and you will likely end up traveling faster in unsafe conditions than you would be traveling if the accelerator was under human control.
Anyway, back to unintended acceleration...
what I'm pretty sure happened is that back when I stopped for my wife to get in the car, I didn't switch into park, just brake hold, and then once the door was closed and she was in,
Here's what happened:
Small 2 lane city street, approached a stop light. Hold Mode on, came to a complete stop, second car at light.
I was picking up my wife at the corner, so she hopped in the car.
Light changed a little before my wife got the door closed, so the car ahead of me pulled away.
Once she was in I stepped on the accelerator, car accelerated as normal, and I caught up to the car in front of me we were moving maybe 20-25 mph.
Proceeded for about 2 blocks, red light ahead.
Took foot off accelerator to slow down, car slowed for a second as regen kicked in, and then started to speed up, not a ton, but maybe 5 mph.
I was already moving foot to brake and as soon as I hit the brake everything behaved as you would expect. I'm 100% sure I wasn't pushing the accelerator. ( I know everyone says that...)
As I looked over at the display, I could see the blue ring around the TACC set speed animating off.
In retrospect what I'm pretty sure happened is that back when I stopped for my wife to get in the car, I didn't switch into park, just brake hold, and then once the door was closed and she was in, I shifted the car into 'drive'. No effect at the moment because of brake hold, but I was really driving with TACC on without realizing it.
I don't know about you, but I've had moments where I've overridden auto steer via the wheel and TACC stays on, which is standard behavior, but not always obvious. I think TACC being on could be a lot less subtle, and the overlap between the control to turn on TACC and put the car into Drive is a little close for comfort from my perspective. The expected behavior on TACC when you are stopped with brake hold on... I'm not sure I'd agree with the decision of 'turn it on, but wait until the user hits the accelerator to start driving for the first time." Seems like something that could be an invisible decision that might surprise people in unpleasant ways. Especially if you are switching between reverse/drive start/stop a bunch in a parking lot or somewhere.
If that's what happened, there would have been insistent beeping from the car when your wife opened the door, and you probably would have had to unlock the door for her to be able to get in. Do you remember needing to do either of these things?
definitely had to unlock the car, or at least I did it before I stopped because I knew I was going to be stopping on the street and wanted to make sure she could get in quickly.
I will have to try from brake hold in controlled circumstances. I don’t think there was a rejection of TACC activation. I don’t remember the sequence of events well enough to say if I put the car into drive a second time, just that something unexpectedly accelerated the car at a time when I expected to be slowing down. I assume it was TACC because I saw that flash of blue onscreen before before I hit the brakes I was on the way to anyway.The insistent sharp triple beeping is the thing that would be definitive. If you heard that the car was in drive. You should have only been able to engage TACC if there was a vehicle detected ahead, and it was more than 5 feet ahead of you.
Agreed, this can happen quite noticeably even if you just hit a bump in the road. It's particularly noticeable if you're using regen with slight accelerator application, to simply maintain your current speed (like on a downhill). Were you on a slight downhill at all in these situations? It would be more noticeable there (but obviously would be noticeable in any case if regen is reduced). Was your regen set to low (you might still notice it though - low regen is not zero regen)?
This needs to be its own thread so more people see it.
NHTSA Tesla “SUA” Petition Created By A TSLA Short Seller who doesn’t own a TeslaThis needs to be its own thread so more people see it.
