Leeboy22001
Had 2019.20.2.1 update last night. Supercharged today to 95%. Just plugged in to top up from 88% to 90% and is now reporting 45min to charge at 8kWh ?.. maybe the update will restore my lost 10% !?
Nope stopped after a 10 minutes after adding 950w.Had 2019.20.2.1 update last night. Supercharged today to 95%. Just plugged in to top up from 88% to 90% and is now reporting 45min to charge at 8kWh ?.. maybe the update will restore my lost 10% !?
The first is TMSpy. The other 2 are from ScanMyTesla. There is much more detailed information available from ScanMyTesla.Could you post some screenshots of your CAN bus data from Scan My Tesla, TM-Spy, or both? It would be interesting to see it from a car like yours that has been apparently affected by the recent updates. Post #115 from sorka in this thread is a good example of both types of data.
That is good news for you!Just was updated to 2019.20.2.1 today i supercharged to 90%. The temperature on the dash said 102 degrees. I got 227 miles, which is actually a tiny bit higher than normal (225-226). My battery pack is a 2012 refurb, no idea when it was installed, but being a 2012 - I assume a long time ago. So my range is 227/.9 or 252 at 100, which equates to 95% of original range. I am a few miles shy of 100K. I got the car at 2018.50.6 - and the charging\ battery data has been the same across this now 4th software update for me. Seen no change in either charger ramping, top charge rate or range. Not that the updates have not changed behavior in others cars, it is not every car, of the parameters which are causing the effects seen are not present on my car. Of course next week it may change, but here is another data point.
Ludicrous 0-60 pull at 95%SOC today, 90F battery temp:
420kW divided by 275V is just around 1525A.
Voltage sag should be less with Max Battery, correct? Is 275V about right under these circumstances?
Please put yourself on this spreadsheet .
There was one guy in the comments on the Electrek article that had 15% just from the update.
Guess it was a software bug then. Glad to hear things are working out.Just uploaded 2019.20.2.1 and my correct range has returned and my slow charging speed from 90 to 100% has been corrected when both were lost with 2019.16.2
Would you provide a before/after detail? That would help as I just updated to 2019.20.2.1 with no adjustment to the previous RM (have not charged yet).
When I uploaded 2019.16.2 my charging was slowed, it took 2 hours to charge from 90 to 99% at 40 amps. Supercharging was slowed also from 90 to 99%. It would not go to 100%. I also lost 3 miles of range but that could be an effect of not going to 100%. I got several notifications to contact Tesla service, they checked and stated my Model S was operating within normal parameters. Yesterday I got 2019.20.2.1 and uploaded. Once that was done I timed the charging from 90 to 100% at 40 amps with a stopwatch. The time was back to what it was before I uploaded 2019.16.2 and I can now go to 100%.
Thanks. Did you get your 3 miles back?
Also, 3 miles loss doesn't come close to the severe degradation other owners are experiencing. Example: my loss is 30 miles.
Yes I got the 3 miles back and technically it is not degradation, it is loss due to a software glitch. The battery capacity is still there but cant be accessed.
AgreedI'll be more convinced when some of the people who've lost 20 or 30 miles report that they gained it all back.
