sorka
For reference, I finally updated the software on my early-2013 Model S 85 from v8 (they managed to fix enough of USB music for it to be an improvement and not a regression). I saw no change in my range level at all. One more data point for "some cars aren't affected at all".
Whatever Tesla has done in the software this time, it's intelligent -- it isn't blind ignorant caution like some of the previous changes. (Like when they keep kicking my charging rate down from 40 amps to 30 amps because their program to prevent overheating wiring doesn't like the voltage of my electrical supply. They're just wrong there. My electrical wiring is top notch overkill, heavier duty than needed, and their algorithm there is junk; the dumb algorithm just can't handle that the mains supply here tends to run a high voltage and have unsteady frequency. Or the "counter based" limits on some people's 90 pack Supercharging, which are just guesswork and not based on actual battery state. Or the "counter based" limits on top acceleration, which are again guesswork-based.)
In this case, unlike previous cases, they're clearly detecting something specific which actually happened in particular batteries and not in others, and reacting to that only when they find it in the battery. It would be interesting to know the technical details.
Because it seems like an intelligent response rather than a blind excess-of-caution response, people probably should do the update; if your range drops, your car probably *was* at risk of catching on fire.
...at which point they should replace the battery if it's still under warranty.
