Circa late-2015 or 2016. Not sure exactly when.
Gone? No. It's a potential issue in ALL lithium-ion cells, no exceptions. It's just substantially LESS likely with the silicon-doped anode.
Yes. It's just less likely.
Apparently Li plating is basically caused by the pressure of charging exceeding the ability of the graphite to absorb the lithium, and it becomes a permanent problem if the metal lithium then reacts to form another compound which doesn't free up the lithium easily. It basically could happen to some of your battery at any time depending on local chemistry conditions at that exact point in that exact layer of the cell. More plating is worse.
You probably wouldn't notice teeny tiny amounts of plating in only a few cells.
But various conditions make it more likely and more common. First and foremost is faster charging (more "pressure'). Second is high states of charge, because graphite which is "already full of lithium" has more resistance to absorbing more lithium. Third is cold temperatures in the battery, because they reduce the ability of the graphite to absorb the lithium. Finally, if you discharge immediately after charging to full, the metal lithium is likely to "unplate" before it reacts with the rest of the battery.
So yes, you are best off:
-- charging only to 85% ever
-- charging as slowly as you can get away with
-- keeping the battery on the warmer side (above 50F apparently) all the time
-- always driving and running the battery down immediately after charging
Obviously this is overkill! If you fast charge sometimes, charge to 100% sometimes, leave the battery at a high SoC occasionally, and do so with the battery is cold occasionally, you'll probably develop a little plating but it's likely to not be enough to worry about.
If you start with a cold-soaked car in below freezing weather, drive it less than a mile to the Supercharger, fast-charge it at top speed to 100%, and then park it for a few hours, you're probably maximizing your potential lithium plating problems. This is as I understand it anyway.
