If you want the maximum capacity and performance of your battery, you need to leave it at a low State Of Charge as often and as long as possible
If that's the case, why anyone would bother to purchase an EV? That's not practical.
If you want the maximum capacity and performance of your battery, you need to leave it at a low State Of Charge as often and as long as possible, see here:
Investigation of Capacity and Homogeneity Recovery of Commercial Cells after Cycle Life Tests
My CPO vehicle is still under bumper to bumper warranty and they are still trying to pull the $175 diagnostic fee. I specifically asked why there is a fee for a vehicle that's under warranty and all they do is repeat the same message. The tech then told me he was cancelling my appointment.
It’s probably true for Li-Ion batteries in general, but as you stated, is not useful for an EV. There is a balance to be had between longevity and practicality. My Stihl Li-Ion batteries say to store them at 20-30% charge for max life.If that's the case, why anyone would bother to purchase an EV? That's not practical.
OK. That’s some change in consumption due to winter! Wow.Sorry to confuse you.
I do understand how projected range and battery icon range work and are calculated.
My point is that using the projected range (from the energy app) without accounting the buffer to calculate battery degradation gives a closer degradation value to the battery icon range degradation number.
Here's how:
Method of Battery icon degradation: 4.3% (424km/443km)
Method of Projected range degradation excluding buffer (my method): 3.5% (79kWh/81.8kWh)
Method of Projected range degradation including buffer (your method): 8.0% (79kWh/85.8kWh)
4.3% and 3.5% are much closer together than 4.3% and 8.0%. This is one reason why i believe my method is the correct one.
Answering your questions:
Yes my numbers are km and not miles. My car has very high consumption because now it is winter here in Finland.
424km, 443km are the battery icon values now and new.
Buffer is 4kWh, sorry my bad.
I don't believe my degradation is 8% because of what i said above.
I believe you need to compare the actual capacity (in a 90D) with 81.8kWh and not 85.8kWh as i believe that projected range does NOT include the buffer.
Im not trying to have my car included into the degradation gate discussion, just questioning the addition of the buffer in the calculations of projected range because to me it sounds wrong.
I'm not defending Tesla here, but Super Charging to 90%, then drive home and connect to home chargers to stay at 90% is just about the worst treatment for a standard Li-Ion NCA cell.
In short, leaving/resting at high SoC will 'strand' li-ion in the anode overhang. The apparantly lost capacity, can be recovered with prolonged periods at very low SoC. This is difficult to calculate/monitor and reports that cars have shut down before reaching estimated range of zero miles argues Tesla cannot. Which makes sense unless you discharge at a VERY low rate.
Today, with the navigation destination set to the supercharger:
- The battery warming up icon was visible on the app
- Charged from 40% to 80%
- Outside temperature: 47F
- Charging speed: started at a pitiful 36kW steady to mid 20kW toward the end
- The cooling pump: Did not run at all
ChargeGate must be 'degradation' dependant too?
I charged my S 70D Oct 2015 with SoC + kW > 98 this christmas with SW 2019.40.2.3. Best thoughput was at higher SoC. Attached App-screenshot shows 42kW at 56%
That's not the Tesla's official best practices for charging. "A happy Tesla is a Plugged in Tesla", "Charge to 90%", etc. has been their recommendations from day one. Tesla has never said anything close to what you are stating either verbally or in writing to the owners. The opposite is true:
An owner asking Elon Musk:
"any insight on the best nightly SoC for battery longevity? 90%, 70%, 50%?
Any software fix for unbalanced cells due to sub 90% nightly charges?"
LikeTesla on Twitter
Elon Musk advising:
"Not worth going below 80% imo. Even 90% is still fine. Also, no issue going to 5% or lower SoC."
Elon Musk on Twitter
How do you think the people who have a very daily commute would charge nightly? They have been told by Tesla to charge overnight to 90% and leave it plugged in till morning.
Has anyone examined module voltage deltas under load? My modules are within a few mv, at both low and hi SOC, but when I look at module deltas under load, I see almost 500mv at 500A. Defective cells/modules or sampling artifacts?
Hmmm, how come you quote Tesla for recommendations, when you assume you have a Tesla BMS that fried your battery?
It is almost a fact that:
- Consistently cycling at high SoC or consistenly rest at high SoC, will hide recoverable capacity loss to BMS
- Consistently charging at high rate and low temperature will permanently degrade capacity
You can take Elon's word that always charging to 90% has no impact, but then you should question Elon and not me, when you discover the impact?
Not sure what you are referring to.
So, you are also in the same boat with regard to the chargegate, looks like.
I fear you have overooked a few details?
The post you indirectly quote states:
roschke, Dec 27, 2019
I supercharged yesterday from 40% to 90%, and when done, the pump ran for 5 hours while the car was parked and plugged in. Lost 1 mile per hour by the pump running off of the HV battery. The outside temperature of about 50F.
So the poster was able to charge 36 kW at 40% with 400V battery pack
My data are 42 kW at 56% so much higher on my 350V Battery pack.
Of course temperature can affect resulkts, but perhaps Battery gate (which has hit all old battery packs) is as well nuanced.
I think it would be nice if you skim posts for new info instead of staements that you can oppose?
(I now understand why this thread is so long!)
I think it would be nice if you skim posts for new info instead of statements that you can oppose?
I propose you write Jeff Dahn and ask if he recommends resting a Model S Battery at 70% or 90%?
At this point I have no clue what you are talking about. You are not making any sense with these posts. You sound more interested in a choppy conversation, jumping from one topic to the next with no clear indication on what you want to prove. Your latest post itself is a good example.
That poster is me, not another poster![]()
'So the poster (== Drosche) was able to charge 36 kW at 40% with 400V battery pack
My data (== jensk2) are 42 kW at 56% so much higher on my 350V battery pack.'
What? I did not oppose anything. I shared my charging experience with others. I think you are badly confused.
No, no, no. Don't propose it to me. You do it and post his reply here. Deal?
