sorka
What they don't tell you about the MCU2 retrofit is the higher vampire drain on pre-Q2-2015 vehicles because the battery packs don't have the standby power supply DCDC which powers the MCU's standby power and body control module directly from the HV battery. The standby supply means the main contactors can stay open (saving ~20-30W IIRC). Without it they have to stay closed, a pump has to run to cool the DCDC, etc. (Yeah, a pump has to run any time to contactors are closed to circulate coolant through the DCDC... so... yeah).
MCU2 was only originally installed in cars with this standby supply and seems to behave... oddly... in cars that don't have it. As in, it stays awake more than it should.
I figure they'll fix that eventually.
You just answered my question in the thread I started:
Gave me quite a shock when I disconnected the 12v battery after the MCU2 upgrade to replace my charge port door and to my amazement nothing shut off. MCU continued to stay on...music continued playing....etc.
I confirmed the contactors staying open and the battery ALWAYS being topped off. The other benefit should be much longer 12v battery life as it's no longer cycling 24 hours a day being drained and then topped off multiple times a day.
That said, my P85D is a Q 1 (3/31 delivered car), not a Q2.
Several days after the MCU2 upgrade, I started getting w094 and u008 contactor errors. Wonder if it's a coincidence or related to the contactors staying open 24 hours / day.
