Use all available thrust to get into orbit. The faster you get there, the less gravity loss. Once in orbit, use the most efficient engines (rVac). Also rVac for deorbit.Do the sea level raptors get used only during descent, or will it also aid in getting to the orbit along with RVac?
On the same token RVac will not be used in any part of the descent maneuver ?
I may be in error. On NSF someone posted that B4/S20 did a full cryo test while stacked. OopsFor the first time, simultaneous cryo test on booster and ship while stacked!
That is absurd on so many levels.In 2015, NASA gave Aerojet Rocketdyne a contract worth $1.16 billion to "restart the production line" for the RS-25 engine. Again, that was money just to reestablish manufacturing facilities, not actually build the engines. NASA is paying more than $100 million for each of those. With this startup funding, the goal was for Aerojet Rocketdyne to produce four of these engines per year.
from the same articleEric Berger reports SpaceX is now building a Raptor engine a day, NASA says
The terminology used there is interesting. What is “tank-to-tank”? Maybe that means “Starship to depot vehicle”?After this initial test flight, Kirasich said NASA is tracking three additional flight tests of Starship for fueling demonstrations. The second test, Kirasich said, will entail a tank-to-tank transfer of propellant, followed by a Starship-to-Starship transfer of propellant, to a complete fueling of Starship from a depot and a long-duration flight to mimic the in-space time of a lunar mission
Numbers 2 and 3 are Starship to Starship (partial, and full refuel (which means a lot if 2s previously), so maybe 1 is a dual tank payload flown on a Starship?The terminology used there is interesting. What is “tank-to-tank”? Maybe that means “Starship to depot vehicle”?
I understand the “Starship-to-Starship” concept because that is what SpaceX has shown in animations.
If I recall correctly, the nosecone of S26 was moved out of the assembly tent with no tiles — which is not standard procedure — and it seems possible it will become the first depot vehicle. S27 has tiles.
The implication is that maybe someone got fired over that incident.Kirasich said that test put “a relatively large amount of fuel” into a cloud of oxygen, triggering the detonation. “That was an operational and planning oversight. SpaceX, in the early days, goes for speed above systems engineering rigor,” he said, calling it a “pause and learn” event for SpaceX.
“They’ve since elevated the level of systems engineering put into each one of these tests, as well as brought in some new leadership into the team down there,” he said, resulting in “additional rigor” in subsequent tests.
This photo demonstrates the mounting of the grid fins very nicely.
Yes, in the Tim Dodd interview earlier this year Elon talked about this difference from F9 and how he thought that probably only 3 fins were actually necessary and maybe even just two. I think it depends on how effective the chines on the booster turn out to be. Note the relationship of the position of the chines to the position of the fins.This photo demonstrates the mounting of the grid fins very nicely.
More "2 on one side, 2 on the other", rather than 4 equally-spaced fins.
The best fin is.... no fin!Yes, in the Tim Dodd interview earlier this year Elon talked about this difference from F9 and how he thought that probably only 3 fins were actually necessary and maybe even just two. I think it depends on how effective the chines on the booster turn out to be. Note the relationship of the position of the chines to the position of the fins.
Fewer fins, less weight, better performance.
How is it the Starship does not have grid fins but is able to control precisely in the last minute and seconds of landing?
This wing like things (chines?) can control when the rocket is falling horizontally higher on the atmosphere, but once it gets straight how is the rocket movement controlled through the air?
