Starship uses a completely different re-entry method than the Super Heavy booster (which will use basically the same technique as an F9 booster). We’ve already seen most of the Starship re-entry profile during the various “hop” test flights, which you can re-watch on YouTube to refresh your memory if needed.How is it the Starship does not have grid fins but is able to control precisely in the last minute and seconds of landing?
This wing like things (chines?) can control when the rocket is falling horizontally higher on the atmosphere, but once it gets vertical how is the rocket movement controlled through the air?
During the final seconds of a Starship landing — when the chopstick arms on the tower will catch it — it will hover and null out its velocity by throttling and gimbaling the center Raptor engines and use its side thrusters (initially cold gas but later hot gas from the autogenous pressurization system) to adjust its position horizontally if necessary.
At least that is my understanding.
