Confirmed. S24 was de-stacked yesterday.Speculation is that S24 will soon be de-stacked so that booster static fire testing can begin
Or roll S24 to a further location, just in case.Also, S25 was removed from the sub-orbital test stand and moved to the High Bay, I presume as a precaution to ensure its safety during B7 static fire testing and then the B7/S24 orbital test flight launch.
I assume that S24 will be moved to a sub-orbital test stand while the B7 static fire tests are performed, hopefully very soon!
It looks like the second orbital test flight will use B9/S25 since B8 has been moved to the Rocket Garden area, joining the other retired vehicles there.
After my last post I realized that there is probably no need to hoist S24 up and onto a suborbital test stand because it has already been fully static fired, it can be kept on the transport stand. I can’t tell if it has been taken off the SMTP or not; maybe it will just be kept on it so it can be quickly moved back back to Stage Zero and then the chopsticks will lift it back onto B7.Or roll S24 to a further location, just in case.
Though it may be it would only fly with B7 so, if B24 fails, it doesn't matter what happens to S24...
Do they need the transporter back or can they crane S24 to the stand?
This type of landing (catch by arms) is an order of magnitude complex then landing on legs. Margins are in low single digit feet. Scary..
Yes, and this screen capture of the LabPadre stream a few minutes ago shows just how wide the chopsticks can spread.SH can go to slow and zero vertical speed and the arms give a large capture range.
I think that info (in audio form) is in the Elon Tom Dodd interview (part 2?)Will the arms stay wide and then close in as the booster (or Ship) descends below the tower?
So many questions !
is there an animation from SpaceX ? (not from 3rd party enthusiasts who are just speculating).
I think full meaning the test went for the intended length, no anomalies nor early abort."full" test duration? How can this be full test?
Also this test only seems to confirm that a flame trench would do a world of good here..
Not sure how you came to that conclusion. The test kicked up a lot of dust but no way for us to tell right now if the concrete pad suffered any significant damage.this test only seems to confirm that a flame trench would do a world of good here..
