I've got the entire Barstow supercharger site to myself at the moment. I pulled in with 58 rated miles (started with 253 RM at the Excaliber and drove with the flow of traffic the whole way) and decided to try one of the temporary superchargers for the heck of it. >>>>
This is helpful info for me for calibrating the Barstow to Kingman leg.
253 - 58 = 195 RM, actual miles 156. You used 39 additional RM, 25% more RM than actual.
Google Maps predicts 70.3 mph "without traffic"
Q: Is this about what speed you averaged, keeping "with the flow of traffic"? Higher, lower? Is 70 the posted limit?
Q: Would driving 60-65 have caused difficulties with trucks going faster or slower ?
Q: No significant headwinds/tailwinds? I know this can vary from day to day in this area.
Only .5Kft net altitude change, but serious ups and downs.
2.7Kft upgrade to highest point inside CA, 60 miles from start, 10 miles of steep 4% grade.
30 miles of downgrade, losing 3.7Kft, with portions of 3.5% downgrade.
Q: Did you see much regeneration on the downgrade ?
Final 70 miles of 1.5Kft upgrade to Barstow.
The simple rule presented at TMC was to allow 7 RM per 1Kft up and add back in 6 RM per 1Kft drop (regeneration inefficiency).
Applying this rule to above elevation profile yields a predicted net correction of 7 additional RM.
My experience is that I can achieve 1-to-1 RM at about 62-64 mph on level ground with no wind.
A rule I derived from TeslaMotors range calculator is to expect reduction of about 3 miles range for each mph increase above neutral point.
Applying these to above matches: 156 + 7 + 3*(70-62) = 187 RM.
EVTripPlanner.com estimates for this route
195 RM using Speed Multiplier of 1.0. Good show.
