There's still a few odds and ends things that visibly need to get done, too. Installing the lamp posts, the parking signs, and the wheel stops (if these are going to be used). And potentially refreshing the paint on the relevant parking lot lines. They may need to pass another inspection or two, as well. But, as you pointed out, all the major work looks finished (assuming the wiring on the Tesla side of the switchgear is complete) and the remaining items can be finished pretty quickly.Saw an update on FB. This one is all done except for the power hookup from NS Power, and the authenticate from Tesla.
Any idea if it will be open by mid July?There's still a few odds and ends things that visibly need to get done, too. Installing the lamp posts, the parking signs, and the wheel stops (if these are going to be used). And potentially refreshing the paint on the relevant parking lot lines. They may need to pass another inspection or two, as well. But, as you pointed out, all the major work looks finished (assuming the wiring on the Tesla side of the switchgear is complete) and the remaining items can be finished pretty quickly.
We stayed at the Holiday Inn Express last year, which has 2 Tesla destination chargers. That worked out well.What are the best options for visitors in and around Halifax until it opens? Scotia Square and a few others show up on plugshare and look pretty good, but it's hard to tell what the best bet is. Recommendations?
Unfortunately, we will be attending an event and staying at CFB Stadacona, so the Holiday Inn isn't an option. We did consider staying an extra day at the Holiday inn Express, but I think we'll be able to make it back to Aulac if I can find one opportunity to charge for a few hours.We stayed at the Holiday Inn Express last year, which has 2 Tesla destination chargers. That worked out well.
Holiday Inn Express Halifax - Bedford | Tesla
Ah, OK, then a local will have to advise you. I didn't try any of the other Halifax chargers since there was no need. If you are driving a S/X and have a CHAeMO adapter, NS now has lots of CHAdeMO locations which make traveling fairly easy.Unfortunately, we will be attending an event and staying at CFB Stadacona, so the Holiday Inn isn't an option. We did consider staying an extra day at the Holiday inn Express, but I think we'll be able to make it back to Aulac if I can find one opportunity to charge for a few hours.
The fleet club at Stad has 4 chargers in the visitor parking area. They’re usually turned off, but there’s a toggle switch on the side to turn them back on. You might need to power cycle them a couple of time before they’ll give a green connection, but they do work. For Tesla’s, they’re going to give you a grounding fault, and be limited to 22 amps at 208 v, but they’ve removed the time limits on those parking spots if you’re there to charge (I’ve tested leaving my X there all day without issue).Unfortunately, we will be attending an event and staying at CFB Stadacona, so the Holiday Inn isn't an option. We did consider staying an extra day at the Holiday inn Express, but I think we'll be able to make it back to Aulac if I can find one opportunity to charge for a few hours.
Thanks so much for the great info! I was not aware that on base chargers were available. Problem solved!The fleet club at Stad has 4 chargers in the visitor parking area. They’re usually turned off, but there’s a toggle switch on the side to turn them back on. You might need to power cycle them a couple of time before they’ll give a green connection, but they do work. For Tesla’s, they’re going to give you a grounding fault, and be limited to 22 amps at 208 v, but they’ve removed the time limits on those parking spots if you’re there to charge (I’ve tested leaving my X there all day without issue).
Other chargers I’ve used in downtown include the following:
1) the Eaton charger at Dalhousie DalTech campus. It’s the only 80amp level 2 charger in the area. Free to use, however it’s only available to the public after class hours (basically after 5pm). It’s accessible via the campus on Barrington, or there’s an access via the Halifax Public Library on Spring Garden road. There are also chargers in the Library’s parking structure, however it’s paid parking there.
2) there’s the Chademo/ccs Flo Charger at the Superstore on Barrington near the train station. Pay to use, of course.
3) two bullfrog chargers in the Scotia Square parking structure (check PlugShare for their level).
There are others scattered around, but those are my gotos when I need a charge. PlugShare is pretty up to date locally, and I highly recommend consulting it if you need to find power.
They’re only a few months old. I’d post pictures, but I don’t want security on my ass for doing it.Thanks so much for the great info! I was not aware that on base chargers were available. Problem solved!
If you're headed this way, snag a couple of those pedestals and drop em off in Salisbury where NB power cares enough to have the transformer here and ready to rock!View attachment 423858View attachment 423859 No changes today. Waiting on The transformer...
Haha - actually, the crew in Quispam told me that Tesla made Enfield the priority for stalls. Good old NB Power making NS look pretty bad!That transformer pad @ least looks pretty,they should do some landscaping @ the Irving gas pumps.
I’ll put my Tin Foil Hat on & blame Irving for the new NB SC’s having transformers ready with no pedestals & NS SC having pedestals with transformer,lol.
