  • The final cut of the 9th episode of the Tesla Motors Club Podcast, featuring Chad Schwitters, the former president of Plug In America, is now available. You can watch it now on YouTube or listen to it on all major podcast networks.
Supercharger - Florence, KY - Houston Road
I’m wondering if this was an issue with the quality of the install by the contracted electrician or something with the supply to the chargers of the electrical grid. Nevertheless for a semi-new SC these are down way to often. I wonder if there is a remedy to preclude them being down so much.
Ski
? I navigated to the SC. Isn't that how you pre-heat it?
While navigating to the supercharger is how you trigger the automatic preheating, I have found that depending upon the ambient temp and how long the battery was parked (depth of cold soak), and driving conditions, it still can take between 1-2 hours of normal driving prior to reaching the supercharger to achieve maximum charge rates. There is quite a large mass of the battery pack that you are needing to get uniformly warmed up which can take some time.
Thanks. That helps. The car sat still at the airport for a week before I drove 3 miles to the SC.
Fiver
1,966
1,749
Utah
This is not even remotely enough time/distance to pre-heat a battery.
I once drove 45 minutes from Park City Utah to the Evanston WY supercharger after parking overnight below freezing. While driving to the charger, temps were around 45 degrees, and my average speed on the interstate was 75-80mph. I still didn't get to optimum temps for supercharging.
Reactions: MattChristian
