They are wrapped up in plastic. I assume that means they are not live yet.You mean they are "wrapped" but functioning? To me, when you say they are wrapped it implies they are not up and running yet.
Okay I guess I’m still confused. I thought you guys were saying the new stalls were open. How many stalls are open and how many are yet to be opened?They are wrapped up in plastic. I assume that means they are not live yet.
That is a huge upgrade! I'm guessing the temp stall will go when the other 4 open, leaving 12 stalls total.4 original stalls open.
4 new stalls open.
2 temp stalls open.
4 new stalls not yet open.
Also, there was a Model X there, falcon door wide open, with an apparently shattered passenger window, and no one around. It was there when I arrived and when I left. I would have closed his door for him, but I don’t know how. I stayed as long as I could, but had to get on the road. I called Tesla roadside assistance to see if they could call him.
Given that I saw a kiddy potty inside, you may be just right.Maybe the kid reallllyyyy had to go
At LP now, 12/26. No change in stalls. 4 new guys still wrapped up in plastic. Using one of the new stalls, I got a max of 110kW with a low SOC. My car was built exactly 1 year ago, 75D. I am not sure what my max charge rate is. These are definitely V3 though. Water cooled and thin cables.
I never got up above 100kW on the V3's, I was on the third plug in on the new section. I have to say though, I drove through yesterday and it was nice to have 10 plugs available. It made the difference between being able to plug in immediately and having to wait. Good on Tesla for adding plugs there. Can't wait for Inyokern to get more plugs.Stopped on Christmas afternoon and used one of the V3 chargers.
Arrived at 10% SOC and maxed out at 194 kW and just under 800 mph.
M3P-
Ignorance is bliss.Teslafi recorded 225 kW yesterday on our stop. Was interesting to see that most others were charging at the V2 stalls rather than the new V3 stalls.
What do you mean by "it", when you say "it says..."? If "it" is the in-car Nav, then you will likely not make it, unless you keep it under 65 (hahaha) and you have zero wind (hahahahaha). If it is EVTripplanner, that is another story. At the same time, that website seems to no longer take into consideration speed and elevation, at least the last few times I tried to use it a few months ago.Anyone make it from LA to Lone Pine without stopping? I have a MX LR raven, but it says I’ll barely make it to Lone Pine from 100%
I've made it from LA to Lone Pine non-stop multiple times. In the winter I have found that it's usually worth a 5 minute stop in Mojave to give yourself a bit of a buffer.Anyone make it from LA to Lone Pine without stopping? I have a MX LR raven, but it says I’ll barely make it to Lone Pine from 100%
Interesting. I guess I never had a car with that much range. 272 was the max I had with my old P85. At least 20 RM are used just going over the Sepulveda Pass. EVTripplanner says that it is 240 with a speed multiplier of 1.2 (this site seemed to give me more accurate information again when I checked yesterday). I drive at 1.1, but 1.2 takes into consideration unpredictables. If I upgrade to a 370 range Model S, then I think getting to LP from LA should be quite easy.I've made it from LA to Lone Pine non-stop multiple times. In the winter I have found that it's usually worth a 5 minute stop in Mojave to give yourself a bit of a buffer.
