toshalot
Seems pretty disjointed but appreciate the info!the map is sometimes behind by a fair bit. seperate teams involved at tesla
Yep, this is pretty typical time frame. Some will go much faster, and some will run longer. June was actually just when the permit was first noticed. Construction didn't start till the fall.Does it normally take this long? This thread started in June.
So basically an entire Gigafactory can be built in China before we get a fully operational Wawa...
Murica
Not up. Says coming soon with no meter. Oh well.My client in the same township is getting held up by the township. So that may be the delay. Permits, inspections, etc. I'm going to stop by there today to see what's up....or not up.
I didn’t. It was rainy and busy, i just quickly glanced over. Maybe I’m wrong, but it seems the opposite side of the building would have been a much nicer spot to put them. Where they have them now, you’re competing with all the traffic to the pumps.did you look up the pole? still not even hooked into the supply lines.
I agree, more people will be prone to park there and block the chargers in the front, rather than around the back of the building.. but they probably also did it to make it easier to see from 73.
Hopefully it's up and running soon!
So power is hooked up on the pole finally!
Guy working there told me today that this Tuesday an inspection is going on and then the following week power should be turned on to it!
Exciting stuff. So maybe before end of Feb?!
fb is truthI saw on a Tesla forum on FB that they're due to be turned on today (Friday)! I'll definitely head over at some point and take a look!
employee that they are doing some tasting and adjustments.
