It has a card reader. But I don’t know if that’s for some sort of Greenlots card or if you can use a credit card. I used the Greenlots app, which was easy enough. I just opened the app and typed in the station ID. Then it started charging.
The only trouble I ran into was getting the CHAdeMO plug to fit into the Tesla CHAdeMO adapter. It REALLY did not want to connect. I’m not sure if the issue is just that both adapters were new, if the Tesla adapter is made a bit tighter than it should be, or if I did something wrong. I got it connected eventually, but it was very difficult.
As for the PlugShare app, it’s on there, I promise! It’s probably an issue of your filter settings. Make sure CHAdeMO isn’t filtered out in your settings. There are probably a few other settings that could prevent you from seeing it as well.
I had a similar issue when I was first testing my ChaDEMO adapter many moons ago. It took some forcing to get the ChaDEMO plug into the adapter, and it took me a while to realize that it was still out by about 1/8"; once I did that, it clicked in and connected; but then charge kept failing. That was because I'd backed in a bit too far, the adapter was pulling to about 7 o'clock angle. I propped it up on the bollard protecting the charging unit so there was no strain and it worked fine. Others have said it worked for them, so I assume having the Tesla end charger plug hang at an angle instead of straight down made the plug pins not contact right in the 3's chargeport. Apparently the car can detect bad contacts.
IIRC, I only got about 37kW max out of it; other commenters said that 50 was about the max ChaDEMO is designed for. And when it was done, it was difficult getting the adapter off the ChaDEMO charger plug... the opposite problem.
I only used it that one time. Perhaps you're right, with age and use it will become easier...
