What software is that chart from. Thanks
It's from TeslaFi
Did you make sure to warm battery first?So, longtime (2.5 years) Tesla owner - just joined the Tesla Motors Club after searching for Tesla Superchargers in Grapevine Tx. Found this thread and I don't think I saw any recent updates on this, but the Texas Smokehouse in Grapevine location is open! Charging at it now. Not positive, but I think it's only a V2 supercharger, not the newer, faster Version. My 2015 Model S 70 is only charging at 26kw (90 mi/hr). I was a little over half full when I started. Charging to 90% and it should be somewhere around 30-40 mins. Not great, but my 2015 is older and doesn't charge as fast. Unlimited and free tho! Lol!
Even so, Shouldn't be seeing mid 20's until deep into the 80's %SOCLike a bathtub - when it's getting close to full, you slow down the faucet.
Stopped by there today to check it out. Noticed that the chargers are grouped by 4 (1A-B-C-D, then 2 & 3). Is that normal for V3 ? Will that change the etiquette for using a supercharger ?
Yes, V3 are in groups of 4, but it doesn’t matter which stall you choose. Any stall can give 250 kW because the Superchargers are tied together on the DC side. If 4 cars pull in at the same time at a low SOC and all plug in right next to each other, multiple Supercharger cabinets will blast off and provide 250 kW to each stall.Stopped by there today to check it out. Noticed that the chargers are grouped by 4 (1A-B-C-D, then 2 & 3). Is that normal for V3 ? Will that change the etiquette for using a supercharger ? View attachment 654631
Charged here 5+ times now and haven’t seen close to 250kw even once. Barely breaks 100kw on a good day. Here now as a matter of fact, and my 2019 Model 3 SR+ is currently charging at 63kw and I just plugged in with 20% left starting out.Yes, V3 are in groups of 4, but it doesn’t matter which stall you choose. Any stall can give 250 kW because the Superchargers are tied together on the DC side. If 4 cars pull in at the same time at a low SOC and all plug in right next to each other, multiple Supercharger cabinets will blast off and provide 250 kW to each stall.
Not sure why it’s charging so slow if it truly is V3...
Think on SRs the max charge rate is 170kW. Still doesn’t explain the low charge rate on yours tho. I’m guessing you preconditioned?
Same here. I just can't believe there isn't a good reason. Maybe there is a break-in period to give it a bit of time, then come back and tighten up all the connection nuts and bolts. Just an FYI to others that may have a home charger. You'd be surprised how the screws on your 1450 or otherwise vibrate loose - not just the Tesla circuit an breaker screws but other household breakers. It's a real thing.Charged here 5+ times now and haven’t seen close to 250kw even once. Barely breaks 100kw on a good day. Here now as a matter of fact, and my 2019 Model 3 SR+ is currently charging at 63kw and I just plugged in with 20% left starting out.
T
Ya, pre conditioned. Could be a battery issue with my car if everyone else is seeing higher charge rates? Might get service to come out and take a look.T
