Why are you so sure that's coming?
There are other ways to accomplish the same goal.
There is a way for the Tesla Model S to be recharged throughout the country faster than you could fill a gas tank.
Here is a completely goofy and unlikely interpretation of this. :wink:There is a way for the Tesla Model S to be recharged throughout the country faster than you could fill a gas tank.
I have it on good authority that the "answer is obvious in general concept, but unexpected in implementation."
Regarding battery swapping, did anyone remember that the Superchargers consist of battery pack units very similar to the Model S battery packs, stacked one on top of another? This may give a hint.
For eight years only.I can't see how it works with owner-owned batteries. With leasing, sure, but if you own the battery how can swapping work?
Sure, Tesla warranties the batteries for everything but 'normal' capacity loss.
Yeah; it certainly won't be acceptable to anyone planning to keep the car beyond 8 years. Thanks to resale considerations, that'll make it unacceptable to anyone. People whose batteries are already dying will accept swaps, obviously, but if you know the condition of your battery, why would you ever accept a permanent swap for one of unknown condition?I've been on the receiving end of a battery swap from Tesla (for my roadster), and I can tell you that no matter what the Ranger tells you about the replacement battery being of similar capacity / quality, I still ended up with an uncomfortable feeling. The new battery becomes 'mine', and I have no idea how the previous owner treated it.
No, chargers. That is the cars have either one (10 kW) or two (20kW) chargers, the SC has the same one's but only 12 of them (120kW output). No batteries in the superchargers as far as anyone knows.
I think we'll find that this is a non-issue in eight years for one of two reasons: Either the batteries are as reliable as Tesla asserts they are (you've no doubt seen them bragging about the pack with 500K miles on it), or the battery technology has advanced significantly enough to make the eight year old pack obsolete anyway.Yeah; it certainly won't be acceptable to anyone planning to keep the car beyond 8 years. Thanks to resale considerations, that'll make it unacceptable to anyone. People whose batteries are already dying will accept swaps, obviously, but if you know the condition of your battery, why would you ever accept a permanent swap for one of unknown condition?
The only way to do swapping is, as someone else said, to make sure that your owned batteries are never used by anyone else, simply stored while you use the 'loaner' batteries.
There's no need to do any arbitrary assumptions. Just start with the assumption that you can't use any owner packs. That means you remove the same number of packs from the whole system as the number of owners needing packs. This might be a huge portion of the network if it's small, but with a large enough network it should be fine. Think of it like a rental car network.Of course it does, do some math with me. If you have a swap station that gets one visitor per hour on average. And, the average time it takes for a owner to come back to get their battery is 2 days (call it a weekend trip), then how many extra batteries do you need on hand to handle the average case?
I think your RedBox analogy is a good one, but you glossed over a lot of detail and thereby drew the wrong conclusion. Yes, you can reserve a movie, and that's exactly what I said you should be able to do with a battery. The thing is, RedBox allows you to then return that movie to any RedBox. You don't have to bring it back to the same one. Also, you only have a limited time to pick up your rented movie, before it goes back in the available pool and you get charged anyway. The whole system is built on the assumption that any copy of Iron Man 3 is as good as any other.
I don't see how this supports the idea of storing your battery for you to come back and pick up at all. It sounds a lot more like the analogy supports the description in my OP. We need to be able to make the same assumption with battery swapping to make it work.
It just requires additional resources be devoted to the swap station infrastructure and a larger inventory for the batteries.
2d * 24h = 48 packs
You'd need to have 48 batteries. Right? By the time you get your first "swapped" battery back and can give it to a second person, you've had 47 other owners stop by for a battery. Actually, you need 49 because you still need to supercharge that battery you just got back before you can give it to someone else and/or you need one to do the very first swap.
Now, what if you could swap a battery, charge the battery you just got, then give it to the next owner that shows up for a swap? How many batteries do you need stock the station with?
One battery. You need to give a battery to the first person that shows up, but then you can charge their battery in the hour before the next owner needs a swap.
Now, this is only the average case, and uses completely arbitrary parameters. Obviously, you need more than this in both cases to be able to deal with peak travel times. Varying the average time between swaps and average time before an owner returns to claim their battery changes the number of batteries you need on hand, but the relationship is really the same. Storing batteries for owners makes the whole system prohibitively expensive.
And I think your math is way off for the "average" case. Better place uses 20 packs per station (1 minute swap, 20 minute to fully charge). 1 pack per station means you are not charging any faster than you are swapping.
Not really. Our argument is over the number of batteries required for lease vs non-lease. The question is if the number for non-lease really "exponential" compared to lease.I believe he agrees with you and is arguing against a non-lease model. If these batteries are leased, then the logistics for storing batteries are simplified considerably, which I believe was his point.
What typical car gets 500 miles on a full tank?? More like 300
Here's my theory on what could happen, and there is some evidence for it too (patent applications, etc.)
A smaller range extending pack that fits in the frunk. The pack uses one of the new metal-air technologies, therefore it is significantly lighter (from an energy density point of view) and may extend the range by say, 100 miles.
This turns the model S into a hybrid-battery car. The range extending pack keeps the main pack charged longer and doesn't drive the car directly so to speak.
Now maybe the range extending pack can be swapped out at the supercharger station for those customers who are in a big hurry. But the ability to have 100 miles more range opens up a LOT of possibilities and lessens the burden on number of SC stations needed in the first place (spacing, distance, etc.) I know having 100 miles of extra range for me means the difference between a trip to the coast without a stop, or not.
You are mistaking the conclusion I was attempting to draw with the Redbox concept. I was only demonstrating the basic concept of reservation and inventory control, which some folks seemed to think was a difficult task. I was not attempting to extend the analogy to the entirety of the debate.
If Tesla is going to force customers into a leasing program then it vastly simplifies the logistics of a swapping system. But I don't see an easy path to do that, while accommodating existing customers.
We know that Tesla has said that barebones coverage of the U.S. requires something like 100 SuperChargers. Whatever the number is, the requirements for swap stations is the same. So lets just assume 100 to start.
Apparently this objection is based on space requirements and the cost of batteries.
The current cost for the 18650 cells that Tesla is using are ranging between $120/kWh and $200/kWh. That works out to between $10,200 and $17,000 for the 85kWh pack.
Depends on the tank size, your mileage and how low you want to go.What typical car gets 500 miles on a full tank?? More like 300
I'm not sure how much cheaper this would be compared to the battery loan case. While it would take about 870 full cycles (~180k miles, using 212 miles/cycle average) for a pack to reach 70% capacity, it will take only about 80 full cycles (~20k miles using 265 miles/cycle average) for a pack to reach 90% capacity, since the degradation is not linear (happens much faster in the start).It might be. By participating in the swapping system, you'd be guarantee that you will forever have a pack with at least 90% of its original capacity in it. Maybe you'll lose the top few percentage points faster because you got a "bad" swap. But, in 10 years the guy who babied his battery is going to have some unknown charging capacity left, while you've still got 90% or more. Regardless of where your battery has been before being swapped into your car.
I'm pretty sure I've heard that refurbishing the batteries is pretty cheap. This cost would just be part of the operating cost of the swap network and be offset by the fee charged to participate.
http://www.teslamotorsclub.com/show...evealed/page13?p=172284&viewfull=1#post172284
That implies an average 1.5 years of use before refurbishing or replacement.
And "refurbishing" a pack requires replacing the cells ones that are 90% capacity or higher. That means you can only salvage cells from packs with ~20k miles or less that failed for other reasons. I doubt there will be many failed packs that satisfy this criteria, so most of the packs will not be refurbish-able to 90% capacity without using brand new cells. You can not mix cells with lower capacity (say 70%) with ones with higher capacity (say 100%) and hope to reach 90% overall for the pack because the nature of cell balancing will limit you to the cell with the lowest capacity (you will end up with a pack with 70% capacity).
This is the reason why even battery lease schemes usually use a 75% (Renault) to 80% (Smart eD) limit for replacement.
