We think everyone will like the upcoming Unplugged Performance updates for our sway bar program (which does include front and rear adjustable end-links). Stay tuned for more suspension innovations on the way, same as always.
Yesssss. Maybe gotta get mine done.We think everyone will like the upcoming Unplugged Performance updates for our sway bar program (which does include front and rear adjustable end-links). Stay tuned for more suspension innovations on the way, same as always.
Once the driver is in the car, there will be uneven load on the suspension.I'm curious as to why you're doing endlinks? I verified on my own bars that there is zero binding of the bars when under the car's weight at least. Maybe they load up under deep compression?
Just got my bars in. These bushings are thicc. Is everyone running soft front and medium rear?#noshimparty
Well, first auto-x with all the MPP alignment toys.... Driver mod needed! The turn in and grip is insane. So much so that I am hitting backside cones frequently, something I hardly ever did before. The car feels so much more controllable though and I am loving the need to re-learn.
The first day I tried 8/6 c/r front and rear on the coilovers. I am not sure I will change anything there yet. Still playing with track mode too. Lot of new variables to learn.
View attachment 551408 View attachment 551409
Front soft, rear med is where I started without MPP FUCA. With FUCA, I’m at soft on both ends.View attachment 551408 View attachment 551409
Thanks @UnpluggedP for sending me the replacement front bar. Overall the new hole locations are ~1/4” closer to the bar’s rotational axis, which means slight increase in spring rate if all else is the same.
New bar on top.
New
Old
Do you have the old version or new version. My neighborhood has about a 4” speed hump and I have a somewhat incline of a driveway but no noises. Granted I just installed them but if you have your front bar on medium and have the old version...that might be the culpritDoes anyone got knocking sound driving slow over uneven bumps after installing UP sway bars? I have a feeling that rubber holder allows bars to move enough to make annoying thuds noise.
Its not touching anything, I'm on a newer version, I checked every suspension nut torque. So my only guess left is that the bar is violently pushed inside rubber bushing. Or flange hits the bushing.Do you have the old version or new version. My neighborhood has about a 4” speed hump and I have a somewhat incline of a driveway but no noises. Granted I just installed them but if you have your front bar on medium and have the old version...that might be the culprit
I'm going to install back stock front bar today and see if that fixes the issue. I never saw any flanges on sway bars before. Everybody just bent their bars to stop it from sliding off...Yes. In addition to possible issues with the bushings, the new bar also has more slop between the flanges where the bushing stops are:
The old bar wasn't this bad. However I already checked with UP and they said the distance between the flanges (663.5 mm) is "correct". Note that the mounts do have a small amount of side-to-side slop in the bolt holes, but not enough to eliminate the gap you see in the photo.
My initial theory was that the sound was caused by the bar moving left to right so that the flanges hit the bushings. However after removing the bar I noted there is a large amount of slop on one side (only) between the bar and the bushing. The other side has no slop at all. I haven't pulled the bushings off to measure everything yet. UP sent me a new set of bushings to try as well. I did note the replacement bushings have a slightly different design so maybe something has changed.
I suspect it's a defect in the bar though, not the bushings, especially if I'm not the only one with the issue.
(and just to be clear, I put the stock bar back on and there is absolutely no noise at all, the noise is definitely related to the UP sway bar)
I'm awaiting some Race Ramps before I dive back in and try to isolate what's going on. Jacking the car up and down over and over again is not my idea of a fun time Luckily the sound is fairly easy to reproduce.
I guess new much wider bushings can help.
Can I get those @UnpluggedP in Czechia?
The word “slop” is probably not the right NOR correct word to use. When I read your comments I’m thinking inches of play but When I installed it the bars I saw about 1/8th on each side so 1/4” in total. there are tolerances built in the bars which I assume is for Tesla manufacture errors.
