Xenoilphobe
Too bad GE made them, if TRANE or another reputable brand had built this, they would still be making them...Good info!
That stinks.
That stinks.
20+ years ago I installed a Themomax solar collector....
I would never buy an electric tankless heater. Heat pumps are only efficient if the air temp is 45 deg. or greater.
I guess I will jump in because I love mine and will install them in all future homes I own.
Mine is gas heated and our electricity bill even with the car is less than we were running when I lived in Texas with our traditional water heater. (Most of that is probably because we are in new construction built in 2010 with good insulation, thermal windows, radiant barrier, etc - its efficient enough that solar doesn't make $$ sense for us. My house in TX on the other hand was built in 1983.)
But honestly I don't worry about any efficiency standards for our tankless water heater - I love the endless hot water it provides. So it doesn't matter how many overnight guests we have and if everyone is taking a shower in the morning or if the dishwasher and laundry are running. Everyone has hot water.
And I got extra storage space in the garage in the nook where the traditional water heater was designed to go.
How often do you acid back-flush it? Most places in SoCal have hard water that quickly limes up the passages in the heat exchanger, so much so that Rinnai warranty is void in the area. Recommendation is to back-flush with white vinegar for an hour every 6 months to keep water passages clean enough to continue to work. You have to take it off-line, connect a pump to a 5 gallon bucket of vinegar and circulate it through the tankless unit's internal lines for 30 to 60 minutes.
For any house that is not vacant for at least half the time, tankless is of no advantage.
PV+heat_pump is hard to beat throughout large swaths of the US but I think they can be made to perform much better when integrated into a smart home system that utilizes PV and ambient temperatures optimally.Rheem it is... I was unaware that the GeoSpring had been discontinued. Mine developed a refrigerant leak. The quality is poor. Which is frustrating because it's not a complicated device. My sister has a Rheem heat pump and it appears to be doing really well. They replaced a propane water heater.
The primary complaint against heat pump water heaters doesn't apply to most people. The majority of water heaters are either in a garage or a utility space where noise isn't a concern.
They're expensive but this is the premier heat pump... no noise issues here... the compressor is outside...
20+ years ago when PV was ~$10/w solar thermal made a lot of sense... today depending on location it's almost cheaper to install PV and have electric resistance heating. It is frustrating that commercially available heat pump water heaters have such a high operating temperature... heat pumps should have a COP of ~2 down to 0F. I know the GE model used R134a... cheap but probably not the best choice for that application. As this type of water heater gains acceptance hopefully we'll see some R410a models that have better performance.
Hang on, i'm confused. We are debating whether we charge at 50 amps or 100 amps in our garages but we have a problem on how much stress a water heater is putting on the grid...?
I replaced an electric tank water heater at an office building I own with a tankless.Absolutely not true... you don't lose that much heat from a tank... especially if it's used daily. The aggregate efficiency of a tank heater is >90%. A tankless by definition cannot be >100%. Not much room for improvement. Heat Pumps in contrast are typically >230% 'efficient'. Using 70% less electricity than tankless.
I monitored the electric consumption on that circuit before and after the change. The tankless uses less than half the electricity of the tank so there is significant savings. You do lose a lot of heat from the tank (it did have an extra insulating blanket).
What do you guys use to monitor individual appliance consumption this precisely?
The office is used just Monday to Friday business hours so the tank spent a lot of time just cooling.Typical usage? How old was the replaced unit? Obviously if you're only using hot water once a week it's silly to store it. Most heaters are used daily... Older heaters did lack sufficient insulation... newer models have ~3" of foam... It's also possible your old tank was installed incorrectly, hot water rises and its possible to establish a thermal siphon and you can waste A LOT that way. This is easily prevented with a 'loop seal'.
... Most people will do significantly better with a heat pump...
For the tankless water heater, as it's the only gas appliance other than heating, in the months that don't use heat, I just use the gas bill. 99% of the gas bill is the connection charge. I'd never go with a tank type water heater again. When it comes time for replacement, I'll likely go with an electric one to get rid of another gas consuming appliance.What do you guys use to monitor individual appliance consumption this precisely?
Your Sig says "6.6 kW, Solar Array, 24-LG Mono X Panels/SolarEdge Optimizers/Inverter - 12.6 MWh Annual Production"I still have excess solar power generation after charging.
