A high AC charge rate would be good, but to really take this out yonder we really need a diesel DC generator as a charger. Preferably embedded in the back underfloor storage if it fits and rated for about 15-20kW. It would need an internal plug, maybe where the 230V output is. It won't have a chance in sand driving with the range otherwise, even if airing down, and can only be used for short offroad excursion. There's going to be a solar option but that only adds another 24kms a day though. Good enough to keep the camp running I suppose.
EM said it would weigh the same as a F150 in the presentation, so I'd expect it to be around 2600kg empty, plus another 1400kg load capacity. Not bad for a overlander...if you can find enough ways to charge it. The ability to run camp from the 230V supply will be nice, so you can use it for induction cookers instead of gas, then you can duct the A/C for heating and cooling to the rear as well. Only thing missing is water tanks, but there's a fair bit of room in the frunk otherwise by the looks.
In regards to the crash testing I'm expecting that the entire front section up until the small b pillar in front of the front door will be the crumple zone. That's over 1m. With the wheel pushing the front door back and open once unlocked. Pedestrian protection looks hard when the vehicle suspension is up, but I'd expect this vehicle will need to be a low rider to reduce drag and improve range. I wonder if they actually do the pedestrian tests when it's low, otherwise I'd imagine it will get hard to offer protection to meet the regs. Most pedestrians are in urban areas, so it would make sense to drive low on flat roads. It would be fairly trivial for them to add some active suspension ride height control either from camera vision or geolocation.
I expect the front bumer to be plastic or composite not SS, so I dunno how it will go for roos down the middle if it also has to be pedestrian compliant. Side will be fine
Reminds me of the Oka actually, straight panels and glass.
