I think you can get the IC to reboot with MCU1 if you also hold the brake pedalYes, with MCU1 about half the time I reboot MCU1, the IC also reboots.
Just adding my 2¢ that I was also told by Tesla service that the brake thing was more of a safety precaution to make sure you weren't moving.I was told by the Tesla tech that holding the brakes doesn't really do anything in the rebooting process. She said that they originally recommended holding the brake peddle just to make sure that people don't reboot while the vehicle is in motion.
Why did you have to reboot?
It rebooted so fast and with both screen rebooting, took me by surprise. I thought the car was glitching while on the road. HahagaThe TuneIn froze while changing channel and LTE lost signal, wouldn't reconnect.
Yes you lose it. Did mine a couple of months ago'Merica,
Did you loose anything in the process like XM/FM radio
The brake-pedal urban legend that just will not die...I think you can get the IC to reboot with MCU1 if you also hold the brake pedal
Got the car back last night and everything is great. All my settings were carried forward. As expected I did need to reprogram both Homelinks (although the garage doors were still listed, they no longer did anything when pressed). The only thing I read about that didn't happen is converting my saved FM stations to Tunein favorites, so I did that manually.My 2017 S is in the SC right now for the MCU2 upgrade (as well as getting the FSD upgrade).
can anyone who has had the MCU 2 upgrade confirm whether or not they can play high rez audio thru the USB port (ie. any flac files higher than 44.1/16
I downloaded this file from Sony which is said to be 96 kHz/24 bit FLAC and it played fine from USB in my 17 Model S. I have been upgraded to MCU 2/HW 3.0.
Download samples
In Europe at the moment SC said it is impossible to upgrade MCU1 to MCU2 if the car is already equiped with HW3 Écluse they don’t have procédure !
It’s only possible to upgrade first MCU to MCU2 and after HW2.0 or 2.5 to HW3 !
Had the MCU2 upgrade done on my 2013 today. What a difference! Still showing as “coming soon” on the website, but 100% can confirm it’s available for the older pre-AP cars now.
Try a different SC. Go for the smaller areas, even if it means driving to one further away. There are too many of us that have received it. Keep pushing.Consider yourself lucky. When the memory finally gave out on my 2013 I pressed hard for the MCU-2 upgrade but was told the home office wouldn't approve it. I would have gladly traded AM/FM for a working browser but the Cincinnati S.C. said no dice. Now the browser works once or maybe twice after a reboot then zilch. Add to that their refusal to provide a written warranty or even a receipt for my $1600 'repair' and you can see why I was less than impressed. My first 3 experiences with the S.C. were great. This time - not so much.
If you have HW3 (installation started in early 2019), then you should already have MCU2, which was installed in cars since mid-2018.
