Wow. I imagine in private sector it is very different ? Like in VW, Mitsu and a thousand others ?
Do you have a solid source on this ?
The private sector normally puts heads of their minions on pikes surrounding the palace to placate the unwashed hordes when bad things happen.
The government grabs the unwashed hordes and puts their heads on pikes to warn others to shut the fcck the up, or you're next.
Same result different system.
There has a been a huge amount written about the DPF scandal, and billions of dollars of peasant money wasted with no discernable benefit. And a large amount wasted on salaries and studies that never did produce good science. Need to keep budget levels, screw the environment.
Here's a primitive overview by some of the scientist involved at the time. Yeah, people were pissed so take it with a grain and do the deep research:
http://www.scientificintegrityinstitute.org/EnstromPPT062309.pdf
Note all diesels have DPF systems even though the actually benefit was negative. The 20% reduction in CO2 and 40% reduction in HC compression ignition systems yield were squashed for an unknown improvement in carbon dust that hasn't seem to changed after billions were spend on it.
Europeans used the American studies as fact before the truth was revealed. There was no rollback once the fraud was discovered.
I believe crap like the CARB DPF scandal is no different than the bozos who have "scientists" that prove EV's are dirty technology and should be abolished.
The way you fix a problem:
First find if the problem actually exists. Blind scientific studies, not an axe grinding study.
Determine root cause.
Devise a list of systems that could mitigate the cause.
Research the list to find the system that is optimal for the case.
Implement the system.
Verify the result of the system are matching the research, if not find out why, and correct the numbers.
Re-evaluate the effect when compared to other possible systems in the list.
CHANGE SHIIT IF YOU ARE WRONG. This is the step that governments find so hard to deal with. When the make a bad decision, they are incapable of changing directions to achieve the desired outcome. They would rather make things worse than admit they are human, or bluntly, to admit they are just like the normal peasants they enjoy kicking or piking their heads.
