Hi. Thanks for the reply. I assume from the above quote you mean 'hard wired to the EVSE'? If so, as you may be aware, in the EU we have lots of Type 2 (Mennekes) sockets of varying outputs - well, either single phase 240VAC at either 16A (~3.8kW) or 32A (~7.6kW), or 3 phase 240VAC at 32A on each phase (43kW). These are compatible with our J1772 EVs by using an adaptor cable with J1772 (Type 1) on one end and Type 2 on the other. The Type 2 end uses the IEC 61296 resistor between PP and earth for current control. I suppose the advantage is that you can then use the Type 2 EVSE socket with either a T2 to T1 cable OR a T2 to T2 cable catering for all EVs… including the EU/UK Tesla Model S which has a T2 socket on it for charging rather than the US type plug/socket.
Sorry, I should have said something like "all pure J1772 systems" - the point being that there's only ever one J1772 connector pair between EVSE and car (and the J1772 specification therefore doesn't have anything in it to cope with detachable cables), while Type2 connectors permit detachable cables with (approximately) the same connectors at each end. The detachable cable support is documented only in the IEC specifications.
So my next question is: Would it be possible to use an adaptor with an EU spec UMC with a T2 *socket* on one end and a standard EU 240VAC 'mains' plug on the other (plug would be country specific)? This would require, I assume, the Model S' charger to be manually dialled back to draw less than 13A (less than 10A would be better) or otherwise the fuse in the 'mains' plug would blow or, if it is a country's plug that has no fuse, cause the plug to overheat… MW
Adapter to what? The EU spec UMC obviously connects direct to EU spec Model S at the car end, and already has standard mains plugs of one sort or another on the other end.
Adapters to other types of mains plug such as UK 13A BS1363? Yes, lots of people do this already, with the limitation you mention about manually dialling down the power depending on the exact combination of plugs.
Adapters to allow the Tesla Model S UMC to be used with non-Tesla J1772 vehicles or Roadsters? Theoretically straightforward, but won't work with off-the-shelf type2->type1 cables. You either need to 'saw off' the type2->type1 cable as Roadster users have been doing to get access to the Ecotricity points with tethered cables, or buy the type2 vehicle-end connector (only made in chassis-mount styles) and mount it in some kind of box to build your adapter.
Suspect I'm misunderstanding your question here.
