I just wanted to publicly thank TonyWilliams for his good work.
Just wanted to say that the JESLA has been great for my situation. I have a one car garage with a 14-50 outlet. My wife drives the Model S and I drive the Leaf. Instead of installing a fixed J1772 station, using the JESLA for the Leaf and then continuing to use the Tesla UMC for the Model S has been great! I have both charging adaptors hanging from the garage wall and all I need to do is unplug one and plug in the other so I can charge both cars with their respective adapters.
Or you could just replace the outlet when it starts to get loose. Only $8.
As to the adjustability of the pilot signal, I don't know, but I intend to find out !!! If we can change the pilot signal with a simple switch, we will.
Not sure if you mean that you plug/unplug the NEMA 14-50, or the proprietary connector between the 14-50 adapter and the UMC. But beware, these things can wear out. Certainly a NEMA 14-50 outlet is not designed for repeated plug/unplug cycles, and the connections will eventually loosen, which has to the potential to start a fire. I image the proprietary adapter connection is designed to handle this, but I'm not sure. Certainly the connection on the car side is designed the handle repeated plug/unplug cycles, as is the J1772 adapter.
My suggestion is to leave the JESLA plugged into the wall, and use the J1772 adapter to charge the Telsa, and and then remove the adapter to charge the Leaf.
