Apparently they just removed on model s and model x from start of jam. Not confirmed yet.
Imagine paying $130k and not have autopark
Imagine paying anything and not getting what was advertised without being compensated for every month not available. Some people coming up to 1 qtr now.Imagine paying $130k and not have autopark
Perhaps someone with technical know how can explain this, but why the ambiguity with the USS as you described (“there is an object somewhere”). In medical USS, we’re able to generate 2d/3d/4d images with USS. Is the limitation the single transducer type used in cars?USS operate in a wide envelope of conditions and are accurate in the distance they report but the information they provide is really pretty terrible.
‘There is an object (I have no idea what it is BTW) n cms from this point on the car, somewhere within a ~60 degree arc of that point (sorry, can’t be any more precise). Oh, and if there’s something closer to the car but higher than ~60cms or lower than 12 then I can’t see it but I will confidently tell you the space is empty. Also, I have no idea what potholes are and I’m scared of deep puddles, so let’s hope those don’t come up.’
The adoration shown for this pretty primitive technology on here is mind blowing. There is absolutely a world of opportunity for a vision based alternative to be better.
I’m surprised there isn’t a thread complaining because there’s no option to start the car with a crank handle at the front.
The medical ones have multiple sensors that cross over at different angles to do 3d I think right ?Perhaps someone with technical know how can explain this, but why the ambiguity with the USS as you described (“there is an object somewhere”). In medical USS, we’re able to generate 2d/3d/4d images with USS. Is the limitation the single transducer type used in cars?
That is a good question that I’ve never thought about, but up thread people are quoting a couple of hundred dollars saved by not installing, what, 8 of these sensors (including wiring and labour)? I suspect the medical imagers are in a slightly different price bracket!Perhaps someone with technical know how can explain this, but why the ambiguity with the USS as you described (“there is an object somewhere”). In medical USS, we’re able to generate 2d/3d/4d images with USS. Is the limitation the single transducer type used in cars?
Sounds like TeslaAre we sure that it didn’t come down to a supply problem? Maybe they would’ve had to curtail production to an extreme level. Maybe it was just an act of desperation and they figured they would deal with the consequences later.
Yes. But begs the question whether this is a sensor issue and if a non-medical grade version would be doable. Challenge with vision is that depth perception is entirely dependent on at least two views of any object (hence why we need two eyes). Much of MV jingles on such a high performing image analysis that it can tear out all these calculations/differences. The human brain cannot accurately measure depth to the level of few inches (try to estimate the distance to an object across the table within 2-3 inches) so seems skeptical that the vehicle computer is more powerful.That is a good question that I’ve never thought about, but up thread people are quoting a couple of hundred dollars saved by not installing, what, 8 of these sensors (including wiring and labour)? I suspect the medical imagers are in a slightly different price bracket!
Same supply problem that is unique to Tesla, that isn’t impacting USS for any other carmaker on the entire globe, and that Tesla never stated was due to supply issues?
While stereoscopic imaging can make ranging simpler, it is not strictly required. Humans with single eye vision can still drive and estimate distance to objects. Tesla performs ranging using single camera vision. Computers have precision advantages over humans when it comes to estimating distance.Challenge with vision is that depth perception is entirely dependent on at least two views of any object (hence why we need two eyes).
It is similar to radar vs. phased radar array. The USS has only one transmitter/receiver, similar to a very primitive “eye spot” that can sense only the light intensity. It can measure only distance to the most reflective (usually closest) object within the field of view (I think Tesla uses the most common sensors with 120’ FOV). It cannot see anything beyond a few meters (signal attenuation/noise) or below 20-30 cm (not enough fidelity). That is perfectly fine for the parking use case.Perhaps someone with technical know how can explain this, but why the ambiguity with the USS as you described (“there is an object somewhere”). In medical USS, we’re able to generate 2d/3d/4d images with USS. Is the limitation the single transducer type used in cars?
Chip shortage affected pretty much everyone. However, they dealt with that in a very, very different way. Audi, for example, gave you a transparent option: either get a car w/o the sensors (and appropriate discount) or wait for the sensors to be available. I think BMW did something similar.Definitely impacting BMW and Ford, and those are the only other car forums I’ve been following recently. People that ordered i4s and optioned park assist are facing huge delays in delivery, and Ford straight up pulled them from the Mach-e like Tesla did… the Mach-e even has a physical parking button that used to initiate park assist, but now it’s been repurposed to just open nav and search for public parking in the recently delivered ones .
Also keep in mind that most other manufacturers that offer it only offer it on their very top trim levels of some models, so they only need to source enough to put them in a small percentage of their cars. Tesla was putting them in every car they sold, so it likely would have been a much bigger problem for Tesla than for other companies, especially as fast as they have been expanding production.
The biggest issue with Tesla is lack of transparency. That, combined with a practice of unfulfilled promises, destroys trust in the brand.
Imagine if they had a track record of delivering on time whatever they promised. We would probably not have this discussion - simply accept that TV will solve the problem and just wait for them to deliver it (on time).
Yep, mentioned this upthread. There is a huge USS supply issue that affected all automakers, it's just that Tesla was drastically more affected since every single car had 12 of them (while for others it was optional and not always 12), plus Tesla sells a lot more units than any equivalent car in its segment. The $114 is largely irrelevant to Tesla, they would have lost a lot more money if the cars were delayed waiting for these.Definitely impacting BMW and Ford, and those are the only other car forums I’ve been following recently. People that ordered i4s and optioned park assist are facing huge delays in delivery, and Ford straight up pulled them from the Mach-e like Tesla did… the Mach-e even has a physical parking button that used to initiate park assist, but now it’s been repurposed to just open nav and search for public parking in the recently delivered ones .
The vehicle wouldn’t necessarily need to use wheel rotation or inertia to judge movement. The tv system classifies objects based on whether they have the potential to move, so it should be possible to assess the cars position in space based on how the static objects around it are moving.It depends how accurate the sensors for movement is wheel rotation vs distance. Also different wheel sizes = different distances. So it might not even be useful enough. The next thing is of course inertial based navigation. But how accurate is that? And when do you know that you are really close to the wall in the front? You can see t he edge of the bumper in the backing camera given that it's clean, but still.
I bought a Tesla without USS and felt Tesla was transparent. I was notified in the app before accepting the purchase agreement that my car wouldn’t have the sensors, but the missing features would be restored through Tesla Vision soon. I knew Tesla’s history and knew there was a risk it would take longer than “soon”, but I still chose to go through with the purchase. Of course I wish my car had the sensors, but as long as Tesla can roll out the missing features within a matter of months, I’ll be fine with it.
Basically $$$ .. medical USS are very sophisticated, very complex, and very expensive.Perhaps someone with technical know how can explain this, but why the ambiguity with the USS as you described (“there is an object somewhere”). In medical USS, we’re able to generate 2d/3d/4d images with USS. Is the limitation the single transducer type used in cars?
I really hope they do not use wheel rotation to measure distance. Wheel circumference is affected by many factors, aside from the wheel size you select in the UX.The vehicle wouldn’t necessarily need to use wheel rotation or inertia to judge movement. The tv system classifies objects based on whether they have the potential to move, so it should be possible to assess the cars position in space based on how the static objects around it are moving.
If you went to sleep in one position in a room and woke up in another you wouldn’t be confused about what had happened or forget about objects you could no longer see because you have a persistent model of your environment in your head.
