No, extra batteries would be huge waste of resources.Or they could send them out with software locked 4680 packs to equal the 2170 range.
Also poster above is a bit off base. At some point as you reduce the battery count, AT SOME POINT (100?) structural pack will not be as stiff in the ways it needs to be, but reducing from say 900 cells to 700, if they are distributed in reasonable fashion, wouldn’t have a serious effect. More to the point, some dummy cells made of cheap composite tubing would keep the entire structural pack just as stiff as the batteries even if you removed ALL the batteries. And something like that for any filler needed would be light which is what you want. Solid epoxy or similar would simply be a huge waste of money and add scads of unneccessary weight.
The properties being gained by using the batteries as as the core material in what is essentially a metal sandwich composite structure are nearly all derived from the ability of whatever you are putting in there not to deform or crush under load. If you didn’t have to run coolant in there, they could literally be thick cardboard tubes and do OK as long as they were bonded well at each end. A sandwich structure that thick gains unbelievable strength just from its dimensions... you just have to hold the two skins together properly, and maintain their distance from each other.
