Mine has now starting to read the 60/80 AHEAD signs as the speed limit sign. That didn't use to be the case. An interesting test case is going through Berridale on the way up to the snowies: coming from 100, limit goes to 60 through town, then back up to 100. Going direction Cooma to Jindabyne when on autopilot, not touching anything TACC reduces the speed to 60, then increases it automatically again to 100 after passing through town. Going the other way, it doesn't go back up to 100 until about 1km after the 100 limit sign on exiting town. Perhaps a discrepancy between map database and signs?
But as of the 36.5.5, it now reads the 60 AHEAD signs as the speed limit, and lowers the TACC speed at that point. The same happens going through Bredbo.
And in Sydney, it still sees the 40 sign on a bus driving ahead of me as a speed limit sign.
Lastly, I can't comprehend for the life in me how the car can possibly ever think it is above a tunnel when it is in a tunnel. The most primitive, simple, trivial test case: any GNSS sats visible (regardless of fix quality)? You're NOT in a tunnel. Conversely, no sats visible at all, you ARE in a tunnel. Would be so simple to do that. Especially when paired with logic that first saw me on the road going into the tunnel... can't magically jump out I'd think
