bcsteeve
I'm with you. My Google-fu says the only thing "continental" about a Tesla is (was) the rubber.Link? I tried search but...well you know.
I took a look at "a" Volt manual that I found online (no idea the quality or accurateness) but the description of "Forward Automatic Braking" didn't list any limitations (which is odd, presumably they have to cap it at some point as the sensors likely can't read quickly enough at max speed) but it did reference what appeared to be another document but I don't know how to find that document.I don't want Cromagnum to accuse me of name calling, and I don't mean to insult your intelligence or anything, but... are you sure? I was heavily looking into a Volt very recently (last month) and I really wanted to buy one prior to a test drive (physically didn't fit well in it, but otherwise awesome car!). I did quite a bit of research and asked them specifically about this point, and was told in no uncertainty that it is ONLY low speed AEB, and that's only with the ACC option (ie. "trimmed out"). Without trimming it out, you get NO AEB.
There's a lot of wiggle room in "while following" and "detected". It might imply ACC on, it might not. It might imply it had to be a vehicle "in your lane" for some minimum period, which would exclude being cut off abruptly.FORWARD AUTOMATIC BRAKING
If the Available Forward Automatic Braking system detects that a front-end collision situation is imminent while following a detected vehicle, the system can automatically apply brakes to help reduce the collision’s severity or even help avoid the collision at very low speeds.
I thought the air suspension too, but I might be misremembering.I'm with you. My Google-fu says the only thing "continental" about a Tesla is (was) the rubber.
Now maybe that's the Canadian configuration, I don't know for sure... but the current marketing seems to support that it is the same in the USA.
I don't think (1) or (2) were in question. I think the question was/is whether AEB functions at high speed without ACC engaged. If it's only with ACC engaged, then the edge between "ACC braking" and "AEB braking at high speed" is blurred.Yes, I am 11,000 miles sure. (1) Only ACC cars get radar. (2) Without radar you get Low Speed AEB.
It is not unusual to find GM understating their specifications.
In California, including all taxes, fees, incentives, it was $28k fully loaded. It's a shop delivery car.
The system may even help avoid the collision at very low speeds
Good point. If it's the latter part, then it's not AEB with high speed, but rather just a function of ACC.I don't think (1) or (2) were in question. I think the question was/is whether AEB functions at high speed without ACC engaged. If it's only with ACC engaged, then the edge between "ACC braking" and "AEB braking at high speed" is blurred.
No, no, no... coming to one's own conclusion isn't what we're trying to do. Nobody's trying to prove you right or wrong. The idea is to come up with THE conclusion, since GM apparently doesn't like to make things very clear. You can't (or shouldn't) assume your car will stop at highway speeds because some light comes on. I doubt you're willing to go perform a conclusive test for uscome to your own conclusion.
The IIHS link doesn't help. There's only two tests, a low speed 12mph test (which Volt was able to prevent collision) and a 25mph (which Volt reduced collision speed by 5mph). Neither test tells you what would happen at highway speed. The Tesla wasn't even tested.Since I don't use ACC (it wastes range) and the FCW comes on at freeway speeds, come to your own conclusion.
2017 Chevrolet Volt
2017 Tesla Model S
People keep pointing to the IIHS ratings. Standard testing is really only applicable when testing standard objects. Cars aren't "standard". Tesla may very well make the safest car on the planet and still score lower than a car that is less safe but panders to specific test outcomes. Yes, Tesla scores lower on IIHS than the Volt. I believe the Volt to be a very safe car. I can't believe it is as safe as the S, on the whole. Mass matters, first of all. But mostly its that massive crumple zone the S enjoys. The Volt still has a large hunk of metal between the driver and the impact.
High-speed autobrake
In the 25 mph IIHS test, impact speed was reduced by 5 mph.
Um, no... that's not what it says.
That's directly from the link you provided.
What am I missing?
Further, they discuss methodology and states that in the "high speed" (25 mph... so lol at "high") it got a score of 1 point out of a max 3, and it was some fraction of a mph away from getting zero points.
Congratulations! That's awesome. Well, the winning part is awesome. The entitlement... not so much. People don't start asking you for money based on the way you got your wealth, it is based on the fact you have it. Someone who didn't before and suddenly did - I would think - would be more attuned to that mindset, but I guess not? I think if I had a windfall like that, I'd be seeking out who I could give it to rather than worrying about them coming to me, but not being in that position I suppose I don't really know.
Switching channels though... maybe you'll consider that your great fortune could come with some moral responsibility. I'm not saying you should stick with Tesla if you're not happy, but maybe you could recognized that the environmental goals of the EV movement are vastly more important than theoretical injuries that may or may not happen due to testing that may or may not occur in a way you may or may not approve. Support Tesla, sue Tesla... that's an economical decision and I could care less. But when you consider what your next car is... remember you can afford to do what others can't, so take your good fortune and lead!
Why don't you do the work and learn the lessons? I'll give you a freebie since you're clearly having trouble identifying it.
"Since you are very prone to making leaps in logic and assumptions" <------ you are calling him names (e.g. characterizing him in very personal terms based on very limited information all of these characterizations are overtly negative).
Oktane gets a lot worse but he shouldn't have to just because he doesn't adhere to the Tesla Defense Bible.
For the 12mph test, you get 2 pts if you reduce the speed by 10+mph -- meaning you're going at 2- mph afterwards.Low Speed - 2pt out of 2 possible.
High Speed - 3pt out of 3 possible.
Low-speed autobrake
In the 12 mph IIHS test, this vehicle avoided a collision. 2 points
In the 25 mph IIHS test, this vehicle avoided a collision. 3 points
Regardless of how you interpret the 2x 2 sentences that IIHS has for the entries on their site, the fact that they consider 25mph "high speed" means that I find their testing useless for answering the highway speed question -- as @stopcrazypp notes.
Do you disagree, @McRat?
Wait, what? I clicked YOUR link and it clearly says it got 1pt out of 3 possible for "High speed" and goes on to say it reduced the impact by 5 mph... the bare minimum for getting 1 pt. What am I misreading????The 2017 Volt scored 6 points:
FCW - 1pt out 1 possible.
Look at the bottom for the chart:
Front crash prevention tests
My car lights up FCW all the time without activating AEB. I hesitate to draw any conclusions without adequate testing (which I don't plan to do).Beyond the IIHS testing all I can offer is anecdotal data.
The LED FCW does operate at over 75mph. So the car knows there is a potential threat. This occurs at a range of 330' at 75 mph since the following distance maxes at 3.0 seconds. Will the car deliberately ignore the threat it successfully identified?
