Just to show what TeslaSpy's sleep settings look like. i created an account but haven't used yet.
that should not matter. my car is parked 15ft away from our couch (no garage) and my wife and my iphones are bluetooth connected.
Makes it easier when it's rainingYou park your car in the living room?
How long does your car usually sit idle before going into sleep mode (if nothing else is pinging it and cabin overheat is off)Yes. 101 interior temp will keep it awake.
Home assistant polling will also potentially do it. Ideally you want nothing using the API other than TeslaFi until you know you have your TeslaFi settings dialed in.
Avoid them both ... unless you want vampire drain.
The most common cause of this happening is the sleep timer kicking in right before you head out. Check your raw data feed from the TeslaFi help drop-down when it next happens to see what you see.TeslaFi doesn't log my morning drive to work correctly, it picks it up on the map like 15 mins into my drive. So if my drive is 60 mins, TeslaFi says I drove for 45 mins, but still went 19 miles.
EastBay to SF commute.
I seem to recall there being a section for you to put in costs. I think it is designed for home charging, not sure how it calculates supercharging.How does Teslafi/TeslaSpy determine the $ cost per drive? Is this based on the rate per kwh you put in the settings (TeslaFi only) or tags (TeslaSpy)? Or, is it based on the cost of the last charge? For instance, if i charge at home, my rate is $0.1, however if i charge at station, it could be $0.2 or higher which would drastically change the cost per drive.
They just added a Supercharger cost setting this week, where you can set whether it uses free or a set rate.I seem to recall there being a section for you to put in costs. I think it is designed for home charging, not sure how it calculates supercharging.
I suppose we are on the crazy spectrum(then again, most people probably wouldn't use a logging app for their car, so...). To see more accurate costs, look at the charge summary page (which I believe should use your cost settings for each charge location).
