I was and electrician before I retired. I think the “granny” charges are fine for occasional use. I use one when on holiday etc. I don’t think they are good as an everyday charger. It’s all about managing unnecessary risks. I’m fairly confident they will go the route of earphone jacks on mobile phones very soon. I would put money on Tesla dropping them in Europe shortly.Obviously I don't fully understand as I'm no electrician, but are you saying that the mobile connector that comes with a Tesla shouldn't be used because of possible shock risk?
Why would they provide you with one of this is the case?
Or are you saying the extension is the problem?
If so, what's the difference?
(Honestly, I'm not arguing here - I'm simply trying to understand)
Anyone on here ordered a model 3 performance at end of April 22. Received the obligatory text from Tesla with a RN number. Leasing company has me down for a sept 30th estimated delivery. Anyone received early?It sucks to be let down when you’re all excited for the big day, but be mindful, you’ve only been delayed a couple days and you’ll still get your precious this quarter!
Try to focus on the positive and get some excitement back for Monday.
For the rest of us, September is still far away…
putting an RCD after an RCD is a waste of time as it will always trip the on in the consumer unit before any after this point would trip. that being said the RCD should be upgraded one one that detect dc leakage as well!Unfortunately my outside socket is fixed to the wall and has no rcd. However it does go to my main breaker box which have rcd's.
However I thought having an rcd anywhere would work. Maybe I need to rethink again.
I did this back in March. At that time they extended it for a maximum of 6 months. I ended up cancelling the extension later on as I wanted the car earlier. Contact them on Tesla chat and they should help.Can I ask if anyone knows or has direct experience of "requesting a hold on an order for a specified time " and how one goes about this. I had heard that Tesla used to offer this but are getting stricter as people were extending on a repeat basis. Can this be done at any stage or do you need to await being allocated a VIN and a car before initiating Anyone with direct experience able to help..happy to receive a private message, thanks in advance.
I would if I could, but as mentioned in a previous post, my garage is detached and has no power in it.
The wall chargers require a direct connection to your fuse box which is 20 meters away from my garage.
This is probably a dopy question but I've not to let such considerations stop me:Its 30amps - but that's not the issue anyway. If the land is yours - no problem you can do it. If the land is not yours I completely understand your position.
I have no front garden.This is probably a dopy question but I've not to let such considerations stop me:
Why must you charge at the garage?
If you have a front garden or paved space in front of your house', you could have a wall point beside the front door. You could the back the car up overnight plug it.
I have probably missed something in the thread which mentions that you live on the 5th floor of a block or have other sound reasons why my front door suggestion is a non starter.
Good luck with the project.
P.S. To the elastic trickery specialist here: is it correct that a PEN fault is more about an earthing failure of the incoming supply than an issue originating with any plugged in appliance or mobile iPads. (like myMY, Lizzie) ?
I have the charger on the gable of the house, and can reverse onto paved area to charge. Wall and charger are soon to be engulfed by our Virginia Creeper, though will of course trim round the charger to keep it looking tidyThis is probably a dopy question but I've not to let such considerations stop me:
All now perfectly clear ...everyones suggestions (multiple) are meant to be helpful ..but your circumstances are pretty unique. I guess moving house is out of the questionI have no front garden.
In front of my house is a path and cycle path, so charging at the front will mean leaving a cable across the path which obviously I cannot do.
My back garden is 10 meters long, and then there is a path approximately 2 metres wide, then my garage (back of anyhow)
My garage is underneath coach houses (flats above garages).. hence no power in the garage.
So I cannot run cable at the front.. cannot run cable down the side and around to my garage as this will cross 2 paths and run in front of the first coach House.
The only way I can go is through the back wall or my garden, sneakily underneath the narrow path and into and through my garage onto the drive of the garage.
Hence why I need a box to sit on the outside near the car that's waterproof and vented.
Hope this clears things up a little.
It does help- thanks.. although you could sneakily run a 6mm armoured under the narrow path and then your good to go with real charger!!The only way I can go is through the back wall or my garden, sneakily underneath the narrow path and into and through my garage onto the drive of the garage.
In the U.K. the majority of electrical connections to properties have a “live” connection and a shared “earth/neutral’. In the very rare situation where the “earth/neutral” is broken but the “live” remains connected to the property a PEN disconnection device quickly isolates ALL connections to the EV.This is probably a dopy question but I've not to let such considerations stop me:
This is incorrect advice. All wall connectors need to have PEN fault detection. A lot of new models from various brands have this feature built in. The Tesla gen 3 wall connector however does not… you WILL require a pen fault detection device which is fed from a type A 30ma RCD. You can get a pen fault detection device with a built in type A RCD. But you also need to change the RCD in the consumer unit as you can’t have different types of RCD types on the same circuit as it can cause faults and issues.I think this is overkill and not needed with a mobile connector charging at appx 7kwh.
This article
EV Charging at Work: Do I Need a PEN Fault Device?
suggests that only 22kwh and above (3 phase) chargers need pen protection.
Check this out courtesy of Frizzy...an active and helpful member of this forum. He has complied a status update of those awaiting delivery ..amongst a lot of other useful stuffG’day mates, I’m popping in here because we over in the Australian forums are comparable to the UK in that: a) we are both right hand drive / left side of the road, and b) we both have our M3 orders manufactured in Shanghai (at least for now).
There’s annoyance brewing over in the equivalent AU forum about delivery time compared to order date. We’re very aware of the Shanghai lockdowns and how this affected deliveries.
Some Aussies who ordered back in December 2021 and even November 2021, who were given estimated delivery dates of weeks, are still waiting for their deliveries.
My specific question(s) for the UK crew is: What’s the earliest UK order for a M3 that is yet to be delivered? Are you all getting your cars quickly now? Is there anyone who has “fallen through the cracks” - that’s ordered earlier than e.g. March 2022 - who has yet to receive their model 3 regardless of variant?
Yes but...no but... for 100% clarity, The Tesla Gen 3 WallPoint is quite smart; it will receive over the air updates from the mother ship.This is incorrect advice. All wall connectors need to have PEN fault detection. A lot of new models from various brands have this feature built in. The Tesla gen 3 wall connector however does not… you WILL require a pen fault detection device which is fed from a type A 30ma RCD. You can get a pen fault detection device with a built in type A RCD. But you also need to change the RCD in the consumer unit as you can’t have different types of RCD types on the same circuit as it can cause faults and issues.
I believe the PEN device is a legal or electric regs and standards requirement designed to prevent "overkill"The charging speed is irrelevant. The car could be “live” at 75v ac or more. And as I said even a small current of 100mV can be fatal.
Its up to you to choose not to worry about that. But I would not be happy to have the potential for somebody to receive a fatal shock just by touching my vehicle. PEN issues are very rare but cause serious injuries every year in U.K.
