gearchruncher
An airplane would be awesome. But as an aircraft designer...
You can get 120 shaft horsepower out of a 300 lb engine for 5 hours with 240lbs of fuel. So 550 lbs gets you 90 KW of power for 5 hours. That's 450 KWh in 550 lbs.
The current 90KWh batteries weigh about 1200 lbs, so you'd need 6,000 lbs of batteries to go for 5 hours (assuming the electric motor is 100% efficient)
The plane you put all of this in weighs 1,500 lbs today (airframe, motor, fuel, people).
So the reason this would be awesome? It means Tesla has increased battery density by 10X. It also means to supercharge at the end, you'd need a 500+KW charger..
