C3XGarage
You’re clearly trying to spread misinformation and fear because of some agenda.I would actually say that 21.9 is more dangerous than not using AP. I actually turned it off this weekend.
My 5ft 3" wife could not put enough pressure on the steering wheel to stop the nanny alerts. It caused her to pull off the side of the road and reset the car so she could reuse the AP. So I tried - 6ft and 210lbs and my normal way of driving had the same issues. Finally the alerts were so annoying - I turned it off.
Sad - 3 years later and AP2 is a downgrade compared to AP1.
The amount of torque force required by autopilot to register a hold wheel is a fraction of the amount of force required to actually turn the steering wheel. If your wife and yourself can’t apply enough force then how would you ever be able to turn the wheel to begin with? You’re either doing it wrong, have an issue with your sensor, or more likely trying to spread negative misinformation.
