Ebrake
Oh and yes, new Wheels this saturday. Was going to have the shop do the brakes for me decided to wade in and do it myself in advance and save the money.
I can see you have the Performance rotor on the front. Did you also swap out the rear rotors? Did you notice any difference in dimensions?
What about the brake shields, do they need to be replaced to when upgrading to the performance discs & calipers?Just to clear things up for people, here is some additional information. I've swapped on and off Base, Performance, and Model S brakes across two Model 3's so I am quite familiar with the setups.
If you are upgrading the Front Only (From Base to Performance) you NEED the Calipers and the Rotors. Everything else is the same. The rotors are 355mm compared to 320mm. Because the Performance rotors are technically a two-piece design, they are actually about 3lbs lighter each. The pistons are the same size, so it is OK to upgrade the front and leave the rear base brakes.
Performance Front Calipers: (1044641-00-D & 1044642-00-D)
Performance Rotors: (1044616-00-D) x2
For the Rear, a cool upgrade no one is talking about is you can use the Performance Rear Rotors with the Base Calipers. It drops about 3lbs per rotor and looks nicer; I am running this setup on my wife's car. Both the Performance and Base Rotors are the same OD (335mm), however the Performance Caliper uses a larger pad. You CANNOT use the Base Rotors with the Performance Calipers.
If you want to retrofit the Rear Performance Brakes you NEED the Calipers, Rotors, and Jumper Harnesses (for the rear EPB).
Performance Rear Calipers: (1044643-00-F & 1044644-00-F)
Performance Rear Rotors: (1044636-00-D) x2
Perf Rear Jumper Harnesses: (1098480-00-D & 1098481-00-D)
The current cost, from Tesla, for all of these parts is $3,540. Considering the cost of most BBK's on the market currently and coming, this is actually quite reasonable (as are pretty much all Tesla parts compared to any other "high-end" manufacturer).
Also do you have a source where I can shop for rotors, jumper harness and shields if needed?
Thanks
Can anyone comment on the "feel" of stock brakes + MPP rotors vs. Performance?
The vast majority of the feel is going to come from the pad, not the rotor. That being said, the stock pad that comes with the performance caliper had much better feel than the base brakes.
Is it just me or are the Performance pads tiny relative to the size of the calipers? Similarly-sized stuff seems to have way bigger pads...
The Performance rear calipers are made of cast aluminum parts. Which requires more material to have comparable strength of parts made of cast steel. Even with more material, aluminum part might still have a weight advantage over the steel part. One undeniable benefit of the large rear Performance caliper is the large visual impact on buying customers, bigger is better. Most consumers would never see the brake pads on their car.Is it just me or are the Performance pads tiny relative to the size of the calipers? Similarly-sized stuff seems to have way bigger pads...
So what does Randy Pobst mean here when he says "even though the caliper is much larger, the brake pedal's still nice & firm?" Start @ 3:23:
