Video shows Model 3 display with Autopilot engaged
Discussion in 'Model 3' started by mrmackie305, Aug 12, 2017.
  1. mrmackie305
    mrmackie305 Member
    Los Angeles, CA
  2. hingisfan
    hingisfan hingisfan_Mark_V
    Kingston, Ontario
    Map looks really nice. Looks like he's following a Model S too.
  3. cdub
    cdub Future Model 3 owner / Current original Leaf owner
    Glendale, CA
    GAH! Vertical video... and very short. But I did watch it like 10 times.
  4. mrmackie305
    mrmackie305 Member
    Los Angeles, CA
    I used my crude Photoshop skills to make the image horizontal. Vertical videos can't stop us from obsessing!
    • Like x 4
  5. liuping
    liuping Active Member
    San Diego
    I'm a little disappointed it did not display the car on the left. Will the all the new cameras I'd really like to see cars in the blind spot on the display.
    • Like x 4
  6. BAven8068
    BAven8068 Member
    Chicago
    Can you actually set your speed with the touch interface, +\- on each side of TACC speed? If so has this taken the place of using the actual stalk on the sterring column?
  7. Thomas Edison
    Thomas Edison Member
    Portland-ish
    I like how it says the battery percentage at the time of arriving at destination on the last step of the directions. I suspect it updates on the fly if you change something (AC, speed). Is that the same on the model S/X? (I assume so)
  8. IhateOPEC
    IhateOPEC Member
    Florida
    Kinda loud, no?
  9. insaneoctane
    insaneoctane Active Member
    Southern California
    If you read the text, it says "Round trip estimate back to starting point"
    I wonder if that means not 55% at destination, but upon returning to starting point (often home)?
  10. insaneoctane
    Southern California
    Loud yes, but the thumps make me think it was relatively quiet so the mic automatically had gain way up.
  11. BAven8068
    BAven8068 Member
    Chicago
    Yes this is the same on S/X.
    The 55% is for the destination. Below that it does show round trip percentage but the actual percentage is being cut off in that picture. You have to scroll down to see the round trip number. Also this is a round trip number back to the spot you started the navigation at, not necessarily your home.
  12. chronopc
    chronopc Active Member
    You can definitely set the speed with the touch interface. I also think you can use the scroll wheels on the steering wheel as well.
  13. chronopc
    Sadly AP2 is still catching up to AP1.
  14. SeanB-Model3
    SeanB-Model3 New Member
    Oregon
    If you look real close you can see the little yellow radar waves showing there is an object to the left. It is right in between the 6 and 7 second mark of the video.
  15. erthquake
    erthquake Active Member
    Good catch!
  16. insaneoctane
    Southern California
    So, the math works out. The driver appears to be about 16 mi from destination and is currently at 189mi. At destination, 189mi - 16mi = 173 mi. If that results in being at 55% (per the screen), does that mean the original range was 173 / 0.55 = 314.5 mi.
  17. chronopc
    Good catch, but is it too much to ask to have the car it detect show up on the screen?
  18. gjunky
    gjunky Waiting for the Model ☰
    Scottsdale, AZ
    Did this model 3 not have heated seats or did they change the controls? The little seat icons the bottom row don't seem to have the 3-level option
  19. BAven8068
    BAven8068 Member
    Chicago
    Yes, but only if he's driving exactly at the rated consumption. Meaning he uses exactly 16 miles of rated range during that last 16 miles of actual distance. More than likely he's not doing that at highway speeds.
    This is the reason I set my battery display to a percentage on my main display. Having it set to show miles can be misleading. More than likely he won't arrive at his destination showing 173 miles remaining. Setting it to a percentage makes more sense, especially since the nav uses a percentage to display what you will have left at the destination/round trip.
  20. jsrawa
    jsrawa Member
    Saint Louis
    I agree. I think this is a very disappointing showing of the AP, I'm not impressed. So what if it senses something there, AP needs to know there is a car there.
