I am currently sat, for some time now at Winchester charging station. How Dan you tell if another tesla user is fully charged but not returned to their vehicle? There are only two charging points here
What would you do with this information if you had it?
I was afraid someone would mention this... PLEASE DON'T DO THIS!Yes, the way to check if a car is done, is press the "open flap" button on the charge cord handle that is currently plugged into the car. You will not be able to remove the handle (locked) but this will light up the green ring around the charge port, even if the car is locked. If the ring is lit green (on solid) the car is done charging. If the ring is blinking, car is still charging.
If the charger is taken, park next to it, leave your charge port open and leave a sign "Please plug me in", so when the other person leaves, they can connect you. It's a common thing here in our community and it works.
[QUOTE="scottm, post: 2111107, member: 25876" I find it odd that Tesla keeps the cable locked into the car even when charging is done. Other EV makers (Nissan, BMW..) allow the plug to be removed once charged.
My charge port auto-closesI agree, there is no purpose in finding out if a car is done charging or not without the owner being there. 'Messing' with the handle and interrupting the charge doesn't help anyone. If the charger is taken, park next to it, leave your charge port open and leave a sign "Please plug me in", so when the other person leaves, they can connect you. It's a common thing here in our community and it works.
Sure you can unplug the cable when its done charging, but supercharger cables are super short. how are you going to use it for your car if the other car occupies the spot? The cable isn't long enough to reach an adjoining spot...
But I don't own a J1772 adapter.With the J1772 adapter in it? I would think it would stay open.
