Just topped off 100% at 250.I took delivery of my X 90D in April of 2016. I have driven 11,941 miles. My 90% is 225. I am charging to 100% this morning, so I can post that when I hit full.
@McManX 42,000, that's a lot of miles! I'm curious of any issues you may have had with the car since you got it? I know lots of people wonder how the cars hold up after significant miles, and yours is by far the most miles I've read on here.
Some people have balanced their batteries and noticed range increases afterward. You may want to try that by charging to 100%, letting the charge complete, and then drive within 10 minutes. I generally do this once a year.
The range estimate displayed in the vehicle is based on several different factors. One important factor is the battery's actual capacity at a given point in its life. This is the amount of energy the battery can hold when fully charged. Since battery capacity cannot be measured without fully charging and discharging the battery, this value is calculated in software. We have found that in cases where the battery is consistently charged to a lower state of charge- between 60-80% -capacity estimation becomes less accurate and tends to underestimate the true capacity of the battery. The result is an incorrect reduction in the displayed range estimate. This does not affect the true range of the vehicle, as the end-of-drive conditions are based on real-time battery measurements of reducing battery power rather than software estimates. In any case we recognize the inconvenience and negative user experience associated with this incorrect and reduced range estimate and we are developing a solution.
The inaccuracy of the capacity algorithm will show up in any Model S that is regularly charged under the conditions mentioned above (it seems it is the case for your Model S). We will develop and implement a firmware updates in the coming weeks (timing TBD) to address the concern you outlined. That being said, the amount of actual energy stored in the battery has not changed. The physical distance you can drive the vehicle from full to empty remains the same, only the displayed estimate has changed. You are correct that avoiding charging to high states of charge optimizes battery capacity retention. You should continue this behavior as best meets your daily range needs. We also recommend opportunistically charging, i.e, charge frequently, charge often. Avoiding deep discharges is another best practice for optimum capacity retention. The advice by the Service Center to "let the range drop down to about 20 miles and then charge it to max Daily Range" is misleading. They are correct that it will mitigate the inaccuracy of the capacity algorithm, resulting in a higher displayed range, but it is misleading as the actual amount of stored energy does not change.
