0-60 in 3.2 is a Model 3 LR.MYLR Fremont. Going to take a look today and verify which motor. Also saw this interesting software hack:
do those VINs come with an "F" at the 8th digits?there were 10x MYPs in the lot at local SC and I checked their rear motors. All MYPs VINs ranged from PF699~702 with manufacture date between 2/28 and 3/2. All the rear motors were 3D1. It was surprising there wasnt any 4D1. And we are seeing LRs out of Austin getting 4D1… so if your MYPs were built between 2/28 and 3/2, you most likely got 3D1
Great stuff!
Any chance you could do that again with ideal conditions? SoC and cell temp as high as possible, aiming for 100%/50°C, which is hard to do if there is no suitable road next do a DC charger, I know.
Just judging by this power reduced 50% run, the new motor is not making a real difference. Torque is pretty much the same as the 3D6 hairpin motor out of China when paired with the Panasonic battery pack. It also doesnt deliver more power at higher speeds. This is comparing EU/China hairpin motor to the US 4D1.
The US 3D1 motor keeps its high torque a little longer, but looses more torque at higher speed. This is apparently still the one to have for good 0-60mph times. The hairpin 3D6/4D1 motors "shine" more at highway speed acceleration.
I've got lots of 100%/50°C logs of 3D1 and 3D6 paired with the US Panasonic and China LG battery packs. So for perfect comparison we would need a similar high SOC/Temp run with the 4D1.
Yes, they all had F at the 8th digit. All were performance models with 21” uberturbine wheels with red break calipersdo those VINs come with an "F" at the 8th digits?
What is your vin? Is it within PF699~PF702 range?picked my MY-P up 2 days ago.
Got it up on the lift (those little pucks I got off amazon really worked nice) and it has a 3D3 up front and a 3D1 in the rear.
Thanks! My VIN is PF695, and the delivery is coming Tuesday. Hopefully I get 4D1 (or does it really matter at all)?Yes, they all had F at the 8th digit. All were performance models with 21” uberturbine wheels with red break calipers
Does it matter?Thanks! My VIN is PF695, and the delivery is coming Tuesday. Hopefully I get 4D1 (or does it really matter at all)?
Nope higher number PF707---What is your vin? Is it within PF699~PF702 range?
Does it matter?
To be determine
Nope newer number PF707---
Ok so it's at least 707
I am not sure which is preferable from what I have read the only thing for sure is the 980/3D1 is an 800 amp motor. no info on the 4D1 is that correct?I'm pf710... Let's see in 2 weeks
You didn't get at delivery?I am not sure which is preferable from what I have read the only thing for sure is the 980/3D1 is an 800 amp motor. no info on the 4D1 is that correct?
ps. I should be receiving the Certificate of Origin in the next 3 days or so and will post up what the declared SAE HP is as well.
Anyone have a new certificate of origin HP they would like to share?
No and I did ask for it directly.You didn't get at delivery?
what is your VIN PF6XX? Thanks!2023 MYLR, build date 1/23, assembled in Fremont. Matrix headlights and 3D1 - 980 motor.
Read post #112 in this thread, Ingenext offered me a 25% discount if I would let them do some testing on the new 4D1 motor. I'm not a big speed guy, however. it looks like you have the 3D1/980 Performance motor, which is typically compatible with the Ghost upgrade.MYLR Fremont. Going to take a look today and verify which motor. Also saw this interesting software hack:
GHOST UPGRADE
It's almost scary.. You need to have the right motor (980 or 4D1). Here's a video to help you find the number motor. The Ghost doesn't work with the 990 & 780 motors. The update transforms your dual motor into a Performance It adds 150 HP to your car... You'll be able to do 0-60 MPH in 3.2...ingenext.ca
Tesla is only differentiating between Base (600A) and Performance (800A) motors. There is a Base and Performance motor in each Drive Unit Category so far. More precisely it should actually be a high current inverter motor and a low current inverter motor, but this is getting a bit too technical I guess.I am not sure which is preferable from what I have read the only thing for sure is the 980/3D1 is an 800 amp motor. no info on the 4D1 is that correct?
