I have an S85 delivered 2/2013 with 64K miles on it. My 90% and 100% rated miles numbers have steadily dropped to a consistent 216 and 240 miles, respectively.
I have the same question as you. For the last year at 90% it has shown 226 miles and at 100% 253 miles consistently on my 2012 P85. Then 4 days ago it dropped to 210 at 90% and 240 at 100% at once. I tried to re-balance. I dropped into a super charger with 7 left. It showed it would take 2 hrs and 20 min to get to 100%. So I moved to a different stall and it now said 1 hr and 40 min. Later at 188 miles charge the charger stopped. It took 20 min for it to reset itself. It started charging again but after another hr passed it was only to 233. I finally gave up being there so long. So much for fast charging at a SC. it certainly didn't charger to 80% in 40 min. Those days are over lol. I will have to try again to re-balance batteries.
Yikes. That is what I suspected also. I made an appointment for this morning at 8am. Crossing my fingers they solve the issue.I'm sorry to say that what you are experiencing is not a balancing issue. You most likely have one or more failed battery modules and you should call Tesla to have your car inspected by service ASAP. The type of range loss you describe is way beyond anything that would be seen with a balancing issue.
Not sure what my 90% is, but I found out what my 100% is when I picked up the car today:
P100DL
100% - 316 rated miles
Looks like my 90% is 282.91 this morning. Picked up car yesterday.
My 90% range has been conistently 232 miles for the past year. Last week my 12 volt battery was replace, and the 2 charging cycles since indicated 208 and 210 miles after 90% charge. Does 12v replacement result in loss of battery capacity data? Perhaps I need to go through a deep discharge and full recharge cycle...
Based on my experience that is not normal. I would contact service and ask them. Sounds like something else might be going on.
P100D 550 miles 90% = 286miles rated. Range mode off.
P85DL 34,500 miles 90% = 225 rated Range mode off.
I just heard from the service center. Taking out my pack to send to Fremont to correct modules that failed.I'm sorry to say that what you are experiencing is not a balancing issue. You most likely have one or more failed battery modules and you should call Tesla to have your car inspected by service ASAP. The type of range loss you describe is way beyond anything that would be seen with a balancing issue.
I agree. Software should recognize the severe voltage drop and alert driver or Tesla. To make it up to me they can feel free to upgrade me to a 100 pack limited to 85 lolGlad you got it resolved!What surprises me is that when something like this happens, Tesla cannot diagnose this through the logs or the car cannot diagnose itself and put up a "car needs service" alert. Seems like a glaring omission.
