I agree with that. It does seem to be correlated to speed requested.I really think pedal position is mapped to a target speed, not to a target torque. Of course, this is just my impression. I could be full of beans.
If I hold my foot steady and road starts to incline upwards the car slows. It does not vary power/torque to maintain a given speed at a specific pedal position.I agree with that. It does seem to be correlated to speed requested.
You're not finishing your thought. It slows....a little bit, but then does increase the power to keep it from slowing too much. It won't let the car slow down to a stop on the uphill. There is a little +/- margin range there. Same with a downhill. It will speed up a little bit, but then it will start applying regen to hold the car back, so it doesn't speed up too much.If I hold my foot steady and road starts to incline upwards the car slows. It does not vary power/torque to maintain a given speed at a specific pedal position.
I tested this on the way home yesterday. This isn't just a little error margin. A target speed is not maintained with a static pedal position... a constant power (and thus torque) is.You're not finishing your thought. It slows....a little bit, but then does increase the power to keep it from slowing too much. It won't let the car slow down to a stop on the uphill. There is a little +/- margin range there. Same with a downhill. It will speed up a little bit, but then it will start applying regen to hold the car back, so it doesn't speed up too much.
Excellent post! I agree. I had many problems with the Tesla Model S regeneration on accelerator:On a thread about the Leaf, there was a complaint that Nissan got it wrong then they had the default regen setting when coming off the throttle to be very light regen. Actually that is the correct way to do things for several reasons. Reasons which non-automotive engineers and non-racing drivers generally would not be aware of. Most of the regen is done on the brake pedal on the Leaf, Volt, EV1, Toyota RAV4 EV (the original one made by Toyota, not Tesla), Prius, VW e-Golf and many other EVs and hybrids. Read some of the history in my link below.
Tesla got it wrong when they put heavy regen on the throttle. It's one of several things they got wrong, but probably the most serious one. It's not stopping me for buying a Tesla or two, but worth pointing out. When I test drove a Model S, I liked it much better with Low Regen. I realize I'm probably in the minority on that, but I also realize most people are very likely ignorant about the reasons why.
Please read and learn: Why Regenerative Braking Belongs... On The Brake Pedal
Also be aware that Tesla itself is not monolithic on the issue. There are engineers inside Tesla who agree that regen belongs on the brake pedal, not the throttle.
Please educate yourself first before commenting.
Flames to /dev/null
Yup. That’s what I remember from the Tesla, and I mostly hated it, but I started getting a little used to it. It was distracting and painful, though. I didn’t like it.I tested this on the way home yesterday. This isn't just a little error margin. A target speed is not maintained with a static pedal position... a constant power (and thus torque) is.
For reference, on my commute home, there's a section where I can set cruise control at 70 and leave it that way for 10+ miles while not having to disengage often if at all. It has some flat, and some gradual hilly sections.
For cruise control to maintain a set speed, it has to vary the power from near 0 on downhill sections to close to 50KW on some uphill sections. The flat sections are right at about 20KW draw.
If a static target speed was targeted by a pedal position, we'd see similar power draw fluctuation as the car attempted to maintain those speeds. I can wedge my foot between accelerator and console side kick-panel, and keep it right at about 20KW for as long as I want (or until my foot falls asleep, lol).
If I do this on the uphill sides I'll slow to less than 40, all the while the power meter stays at a constant 20KW. On the downhill sides I'll accelerate past 85 before I have to abort, as it's continuing to gain speed.
So I'm pretty sure a given pedal position targets a given power/torque, not a given speed.
Bjorn did a video that showed how much energy he could save by going into neutral for hills as opposed to doing the regen-re-accelerate mess. It was a lot, and saved a lot of wear and tear, adding miles he could travel.Same here.
Coasting is always more efficient because regen has losses both in taking the energy back into the battery pack and taking from the battery pack back into motion.
I disagree. I could do very-near-limousine stops in my Mercedes all day. The braking computer was that good. It was their SBC system, so they discontinued it due to cost.Unless you drove over an expansion joint or pavement irregularity while braking, then it felt as if the car lurched ahead--really poor brake feel. And the third generation was so bad they had to recall the cars to fix it. The only way in which regen on the brake pedal can be done smoothly is to have the friction brakes do a lot of the braking so that the transition isn't felt. It's a bad idea.
I still can’t fathom why they cancelled that car. I’ve read the official reasons and the conspiracy reasons, but none of them make sense!GM did it very well 20 years ago in the EV1; Toyota a little later with the second generation Prius.
“One man’s opinion” is a mantra of the Marxists.One man's opinion, with the linked backup being...one man's opinion.
How is it right that when my right foot got tired, my car would come to a stop on a freeway when I gave it a rest? That’s downright stupid! Tesla got it wrong. They should open source their software, so we can fix it. It would require some validation before usage, of course.Regen does not belong on the brake pedal, it adds unneeded complexity and poor brake feel. Tesla got it right.
Coasting was managed by the computer in my Mercedes very well. It interpreted no pedal as coast, and throttled the engine and transmission gearing to a very good state for coasting, using very little energy, but just enough to stay sane, and be ready for the next input. It was almost impossible to trick the Mercedes computer into doing the wrong thing, and that was on some really weird situations, so I didn’t mind it at all.This depends on road conditions. Coasting in an automatic uses gasoline as opposed to engine braking and coasting in an EV uses energy to counteract the counter electromotive force as opposed to regen. It's easier to just maintain speed if you wish to "coast".
Of course slowing down just to speed up again is wasteful so one must judge base of future road conditions (if a hill is coming up etc).
I've never once been either distracted by it or found it painful.Yup. That’s what I remember from the Tesla, and I mostly hated it, but I started getting a little used to it. It was distracting and painful, though. I didn’t like it.
I think my Mercedes used a combo method, smoothing pedal input into constant speed and ramping out of that just a bit for hills, prompting me to input higher or lower pedal as the hills changed, but only slightly, and as soon as I did, the car would comply with my wishes. Absolutely wonderful to drive.
Supercaps are ideal for that. Car needs just 100-300Wh of capacitance for regen. It will help with regen efficiency. And also overall efficiency.How much of this problem is caused by regen on a Tesla being so weak a stopping force? Could it work better if there was a small bank of supercapacitors that could soak up more energy faster?
