So I discovered I have what looks like a Nema 6-30 plug in my garage. The house was built in the 1950's so I am a little nervous about the wiring.Here are some pics:
So my questions are, is it safe to use a 6-30 outlet? How can I tell if my wire is the proper gauge?
The 6-30 does not have a ground wire. It just has two hots and a neutral. How hard would it be to add a ground and change the outlet to a Nema 14-30? Does having a ground wire add an extra layer of safety?
Right outside of the garage looks to be a ground wire connected to my outside faucet:
Right below the breaker box appears to be that ground wire also connected to a rod in the ground as well as a wire running from the breaker box to that ground rod:
I plan on getting an electrician to look at it but wanted to get peoples thoughts here first before potentially wasting an electricians time.
Thanks in advance for any help provided!
