jpvdheijn
Dit zou wel eens kunnen komen doordat er geen standby powersupply is bij de oudere modellen?
Wiki - Sudden Loss Of Range With 2019.16.x Software
Why not to include these older battery cells heating up prematurely (unexpectedly), being detected to trigger the cooling action? Because that's not what's happening. Happy to review your car's logs. Just bring it by.
teslamotorsclub.com
Regarding MCU2 upgrade. You have earlier mentioned that updating to MCU2 in cars with no standby supply would lead to larger vampire drain. I think earlier you mentioned that this was implemented in mid '15.
My 70D S' birthday was on 3. jul 2015, has my car a standby supply - I'm considering upgrading to MCU2
There are updated pumps that are a little quieter, but internally seem to be the same just more mass to absorb sound around them. Not 100% sure why they would replace them with regard to a slow supercharging complaint... unless it was an issue with something not reporting in as it should causing the thermal management system to be more cautious...... or just a "look, we did something" type of "fix".
I believe these started going into 90 packs first, then eventually in all refresh cars and all X's. If I had to bet, your 70 does not have one.
