Thanks @stedes Do you know anyone locally with one?
Thanks very much!Send message to Anthony Agius (@decryption on Twitter). He’s got one and writes EV articles for drivezero.com.au and I’m sure he’d be happy to help you.
There are some good Australian you tubers doing ev stuff. Also look up ludicrous feed and tesla in the gong.I've just discovered that the Telsa supplied charger is not "smart" in that it will draw energy from the grid if it needs to. I now realise that Tesla a going to supply me a product which won't be useful to me as I want to maximise my solar charging from panels.
That was a really helpful video Scully, thanks.
I just found Tesla in the Gong's blog... hilarious!Also look up ludicrous feed and tesla in the gong
Well, yes. I would think though that on Tesla’s “to do” list is to provide a smart charging capability for those with a PW2 and a Tesla, since Tesla can communicate with both, it knows when there is solar excess, and could tell your Tesla to take the excess.I've just discovered that the Telsa supplied charger is not "smart" in that it will draw energy from the grid if it needs to.
Until then, adjust your charging timers to maximise solar charging. That’s what we did with our LEAF - on the 3 days of the week it is not driven to work, it starts charging at 07:30 hence takes the solar (if there is any). It only draws 2.4 kW so anything above that goes into PW2
The occasional cloud doesn’t matter much. It needs to be overcast for extended periods to not generate any meaningful solar. I guess my point was that, since we don’t have a “smart” system, the next best option is to manually shift demand to maximise the likelihood of charging with solar. It won’t always work, but it does work a majority of the time.“if there is any”. That’s surely the problem. In Sydney, often the clear skies are variable, with periods of cloud interrupting good sunshine.
How much will it charge in 4 hours given an optimal setup? Also is that EV tariff for the whole house and not just the EV? The meter would not be able to discriminate would it. So could u run your heating/AC on that rate too. I am also on Powershop and plan to switch several properties to the EV tariff If I can.Powershop now has an EV tariff that for me in Sydney is 7.94c/kWh. This is between midnight and 4 am. Hardly worth the expense of doing anything else!!
I’m using this plan with Powershop. With the HPWC and a 3 phase connection you can get 44kWh into your car during the low tariff period (0000-0400). It does seem that the incidental consumption in your house gets charged at the same rate, although I am not exactly certain.How much will it charge in 4 hours given an optimal setup? Also is that EV tariff for the whole house and not just the EV? The meter would not be able to discriminate would it. So could u run your heating/AC on that rate too. I am also on Powershop and plan to switch several properties to the EV tariff If I can.
Perhaps it might be worth the expense of a Zappi if one does not already have a Wall connector, have solar and a need to charge during the day as well.
I run whatever i can at that rate. There is no discrimination. So, yes, i run my spa and aircon. I get 100km per hour on my 3 phase setup, but I have dual chargers on my 85 from 2014. Plenty of time to fully charge from empty.How much will it charge in 4 hours given an optimal setup? Also is that EV tariff for the whole house and not just the EV? The meter would not be able to discriminate would it. So could u run your heating/AC on that rate too. I am also on Powershop and plan to switch several properties to the EV tariff If I can.
All good info. Interestingly I am with Powershop at three properties, none of which are on the EV plan. While investigating the deal I see these EV plans involve time of use charges that range from the super cheap tarrif 0000-0400 that may only be 9c depending on which state you live in, to over 40c at peak which is very high (42 in Vic). Whereas my existing Powershop plan is flat rate at 28c 24/7.I’m using this plan with Powershop. With the HPWC and a 3 phase connection you can get 44kWh into your car during the low tariff period (0000-0400). It does seem that the incidental consumption in your house gets charged at the same rate, although I am not exactly certain.
In NSW Powershop will pay you more for your excess solar during the day than it costs you overnight to fill the car. For that reason I have not gone with a Zappi.
That's why it doesn't make sense to me that powershop offers this rate. In fact, I'd rather they charge me less at the shoulder times as they are the high cost times for me (unless it's cloudy).I run whatever i can at that rate. There is no discrimination. So, yes, i run my spa and aircon.
