I would stay. Perpendicular parking and auto screen brightness, which I have no use for, would be a fair trade off for much better local street handlingSo I'm on 17.17.17. Should I update? Sounds like the update is worse!
It's true, and that's why in this case terminology is significant. Autopilot behaves very much like real autopilot on an airplane. The pilot is always responsible to fly the airplane and execute changes.Ok. Will stay and not update.
To be honest, after using autopilot for 1500km road trip, it seems self driving is SO far from being a reality. All it really is fancy cruise control. Self driving implies much more intelligence. There are so many situations where I needed to take over. And when I show it off to people, I always need to answer their questions by admitting that the system cannot read traffic lights, stop signs, avoid pedestrians or cyclists etc. All it does is stay within the lines.
The following is based on an 18 mile round trip from rural farm into small town 9 miles away. There was virtually no traffic. The roads were relatively flat, no large hills, overcast, early evening.
The update was done with the car's cell connection, 1 pip on the cell connection indication. It went quickly, much quicker than the initial update screen indicated.
A change (from 17.18.50) is that on secondary roads the display used to say autosteering was unavailable. Now it tells you it is restricted to 45 mph. This was on a 2 lane road with a 55 mph speed limit.
It is squirrelly at low speed crossing RR tracks at 35 mph in town, abruptly attempted left turn. It was quickly caught.
It makes abrupt inappropriate turns at slow speeds in town.
These are not gentle, they are fairly aggressive. I held the steering wheel and caught things early, I've got no idea what would have happened had I allowed the car to complete the maneuver.
The car seems quicker. This is purely subjective. It might be wishful. It is an S75D, mfg date May 2017. I do not know the motor codes.
Autosteer works well on a non interstate divided highway, ~5 miles each way, 55-65 mph.
Speed limits seem more accurately represented. The speed limit generally seems to change right at the sign, one was slightly after the sign, one was missed. I don't think it is reading signs although it might be. It is much more accurate than previously.
I'd do the update, just be cautious of the low speed sudden moves. I would not use autosteering in town if there is traffic.
I did attempt to use the windshield washer. It turned out the reservoir was bone dry so wasn't filled at delivery. New owners might want to check for washer fluid before needing to use it. The resevoir doesn't take much fluid. It worked once filled.
I wouldn't be surprised if Tesla is using existing AP1 vehicles to build a new database of speed limit signs."A change (from 17.18.50) is that on secondary roads the display used to say autosteering was unavailable. Now it tells you it is restricted to 45 mph. This was on a 2 lane road with a 55 mph speed limit."
Clearly, there must be a new database being used. As I noted yesterday, here in Naples, a few local 45mph (divided, 3 lane) roads that previously were 5+mph restricted are now unrestricted.
HW1 X....
It seems quite unable to handle roads with sharp turns. Why would it knowingly cross over the center line on a one lane (each way) road? This is while doing just 8mph ...
Looks like the car ahead of you did the same thing. But it's not blue, so the Tesla shouldn't have been using it for tracking.It seems quite unable to handle roads with sharp turns. Why would it knowingly cross over the center line on a one lane (each way) road? This is while doing just 8mph ...
This is definitely not road conditions. The same behavior happens on all roads, all lanes, all lighting conditions. I see multiple Teslas every day here, so if our roads had some special sauce screwing this up other's would have reported as well.
It's also interesting that the vehicle knows that it isn't in the center of the lane and continues to drive this way. I even allowed it about half a mile to see if it would eventually snap out of it, I hugged the curb for half a mile with the best performance coming on a slight curve when the car got inside the lane for a few feet.
If this were a damaged sensor, I would expect the dash to show the car centered. If this were a change in AP software, I'd expect more reports (I've seen one other). I certainly hope that the SC has an explanation after fixing it. It's quite frustrating to be without lane keeping for a week, I didn't realize how often I use it.
Mine still works (AP1)
