rush6410
With the new update and several hundred miles with the update, I can report that this is by far the most significant improvement since I have had my X (Dec 2016). One major improvement which I have been complaining about for a very long time is how AP would not deal with double solid lines. I can now confirm that the problem has been resolved. In all areas where AP failed completely with double lines now works. It picks the inner most line and follows. Seemed like an easy fix. All I can say is it is about time. I have two 90 degree S curves with intersections mid curves leading to my neighborhood. AP always had trouble traversing the conditions. AP 1 wouldn't even attempt. AP 2 started even with AP 1 and has slowly improved overtime. The the latest update, completely traversed the S curves without slowing down. I would consider using AP through this part of the road as a very good test of capabilities. The two large left and right S curves has two intersections mid cure where lines drop completely through the intersections. In addition one of the S curves increases elevation peaking mid intersection and dropped lines. So, the fact the latest update traversed where all other versions failed miserably tells me we are seeing progress. BTW, through that section of the road the speed limit is 45. So, I am traveling at a good clip considering the challenges. Just wanted to share my experience.
