Krazaak
Perhaps I misunderstand, but does AEB not kick in if I fail to react to the FCW alert?That would be a FCW alert, not AEB.
Okay, that’s how I understood it. AEB isn’t something you’re going to want to test, but you can test FCW and be reasonably sure AEB will intervene and not end up testing your local collision repair shop.They are separate and either one, or both, can be turned off. FCW can be set to alert "early", "normal", or "late". if you have FCW set to "late" and you don't react, and conditions don't change, AEB would likely trigger very quickly.
Think of it this way:
FCW: Alerts if it thinks you might hit something and you could do something to avoid the collision.
AEB: Is triggered once it knows that you are going to hit something. (Where nothing you could do would avoid the collision.)
Sorry, my comment was missing a semicolon. My statement was in response to question about testing AEB. You can test FCW and be reasonably sure that AEB would intervene if you ignore the alert. By the time you find out if AEB is going to kick in, you’re going to collide.No, AEB will not prevent a collision. It is only designed to reduce the severity of an unavoidable collision.
So elaborate on those videos you see on YouTube of our cars doing a swerve around imminent crashes? Because sometimes I’m under the impression the car will swerve to prevent a collision in some cases. Otherwise it may just be the car warning the driver and them swerving manually.Sorry, my comment was missing a semicolon. My statement was in response to question about testing AEB. You can test FCW and be reasonably sure that AEB would intervene if you ignore the alert. By the time you find out if AEB is going to kick in, you’re going to collide.
Disclaimer: I may be horribly wrong
That's a good question and I don't know the answer. It's my assumption that while driving with autopilot active, the vehicle will slow down to avoid an obstacle and potentially move over within the lane to avoid something coming from the side. It my belief (and my hope) that the vehicle would never leave the lane without manual intervention. I'd rather push somebody back into their lane if they decide to sideswipe me than have the car swerve into oncoming traffic to avoid them. I think that autopilot will stop to avoid a collision if it properly detects an obstacle and has sufficient time to react.So elaborate on those videos you see on YouTube of our cars doing a swerve around imminent crashes? Because sometimes I’m under the impression the car will swerve to prevent a collision in some cases. Otherwise it may just be the car warning the driver and them swerving manually.
It was as if the car knew the turn was coming up and how severe the curve was without the drivers display indicating that the car was visualizing the curve through the forward cameras.
Is this evidence that Tesla is now using onboard high-precision mapping? Or is TACC using Google Maps to anticipate curves based on the known position of the car on the map? Or both? I don’t know.
Interesting, have to check this out. I’m sure you would have mentioned if you had ‘blue car syndrome’ and were locked onto the car in front of you. Since not, it has to be advance camera use or mapping. I always wondering why maps weren’t used to tell when to decelerate in advance.Last night I received the latest firmware being discussed here. I have EAP. Today I tried AP and TACC in the following scenarios:
280 freeway from San Mateo to Page Mill Road (California, San Francisco peninsula area): Within a minute after activating AP on the freeway I realized that AutoSteer was noticeably more stable and was maintaining lane position better whether the road was straight or curved. This was at 0800 and sometimes straight into the sun which was fairly low, a challenging situation for the cameras.
Hwy 35 (Skyline Blvd) from Page Mill Road to Hwy 92: This is a narrow curvy two-lane road, I used TACC for most of it (not AP), set to 45 or 50mph, and was impressed by how the car automatically slowed down for tighter curves and then accelerated after the curve back up to the speed setting. It was really remarkable how good it was! It wasn’t perfect, but it was very good. I’ve driven this road over a hundred times (never used TACC on it before) and in most cases the car took the curves at speeds that I was comfortable with. Sure I would have taken some of the curves somewhat faster, but in general the car got the speed right in a curve.
But here is the really amazing part: multiple times, the car started to slow for a tight curve BEFORE the lane lines on the drivers display showed the curve. The lane lines shown on the display would be straight lines and the curve about a hundred feet away or more and at that distance the car would begin to slow down to a speed that I felt was very appropriate for the curve.
I had not set a destination in the navigation so the car was not following a navigation route. Again, this was with only TACC on, not AutoSteer.
Maybe others have already seen this TACC behavior before the latest firmware release (2017.42). I have seen hints of it on 2017.40 but nothing like what I experienced today.
Sorry, I should have been clear that the behavior I described — TACC appearing to know a tight curve was coming up before the drivers display showed curving lane lines — happened when there was no car in front of me.I’m sure you would have mentioned if you had ‘blue car syndrome’ and were locked onto the car in front of you
I cannot rule that out. But if that is the case, why would Tesla choose not to show that data to the driver? If the car is taking action based on knowing a tight curve is coming, why not show the curve on the display? Doing that would reassure the driver that the car is slowing for a good reason. On the road I was on, if it was night and the driver was not familiar with the road, the driver might wonder why the car was slowing and might override it because they couldn’t see the curve yet (there are no streetlights by the curves I was describing).Another option is that the display on the dash showing the upcoming curve is behind (delayed) what the cameras are actually seeing?
the other items seem like they’re more a representation of their medium term roadmap rather than present capabilities.
I've noticed that this update has a more sensitive forward collision warning. I'm getting the alert more frequently and my driving habits haven't changed as far as I'm aware.I get audible AEB alerts fairly regularly when I'm coming up behind somebody slowing to turn right. I've never had it actually intervene because I've never been in a situation where a collision was imminent.
Wow, I've never actually read that before. Probably a good thing, because I might be unhappy with the current state of autopilot if I had...There's Tesla's Autopilot described. Just look how they describe it still today... not much resemblance with the software shipping in the car... Autopilot
