Da Nile may not be just the rearranged letters on a conference room sign at the Fremont Factory. Your data source appears to be incomplete, unduly focused on the battery category of energy storage and possibly driven largely by: "California’s energy storage mandate (AB 2514) added a twist to existing demand for energy storage. Adopted in 2010, the bill required California’s three largest power generating utilities to contract for an additional 1.3 GW of energy storage power generation (meeting certain criteria) by 2020, coming online by 2024....
According to records available from the Department of Energy, the following California energy storage projects are announced or underway:
At the Halfway Point: The Effect of California’s Energy Storage Mandate
DOE has a searchable Global Energy Storage Data Base maintained by Sandia National Laboratory. Worldwide the database shows 1,630 projects with a rated power capacity of 193.2 GW.
I ran three quick searches for the USA-only; since, aside from American Samoa, I haven't notice announcements by TSLA, SCTY or AMS about projects outside of USA.
The first search was projects "under construction":
DOE Global Energy Storage Database
Results were 6 projects with total rated power capacity of 78.5 MW, size and description (1 mistake --a 20 MW, Vanadium Redox Flow Battery in China) :
- Advanced Rail Energy Storage Nevada, 50MW, Gravitational Storage
- Marengo Project, Illinois, 20 MW, Li-ion Battery
- Redding Utilites, California, 6 MW Ice, Thermal Storage
- Green Omni Terminal Demonstration Project, California, 2.6 MW, Electro-Chemical
- University of St. Thomas, Minnesota, 0.25 MW, Electro-Chemical
- Whole Food, Hawaii, NA, Li-ion Battery
The second search was "contracted" projects:
https://www.energystorageexchange.org/projects?utf8=✓&technology_type_sort_eqs=&technology_type_sort_eqs_category=&country_sort_eq=United+States&state_sort_eq=&kW=&kWh=&service_use_case_inf=&ownership_model_eq=&status_eq=Contracted&siting_eq=&order_by=&sort_order=&search_page=1&size_kw_ll=&size_kw_ul=&size_kwh_ll=&size_kwh_ul=&show_unapproved={}
Results were 47 projects with total rated power capacity of 2.2 GW.
Yes, many were in the Li-ion Battery Category (26 of the 47). The largest LI-ion provider appeared to be AES with 100 MW at Los Alimitos, 30 MW at Escondido and 7.5 MW at El Cajon, but I did not see AES' 20 MW in Kauai. Second place appeared to be TSLA in its various forms: 20 MW at Mira Loma, SCTY's 13MW in Kauai, and AMS' 50 MW for hybrid buildings (SCE), 3.5 for Inland Empire Utilities, and 0.75 MW for Cal State, but I did not see the 7 MW for Irving Ranch Water District.
There also multiple other Li-ion providers, including:
- Convergent's 35 MW for SCE
- Hecate had 3 projects, totaling 51 MW
- GE/Con Ed had at least one 2 MW project
Other solutions included:
- Two Pumped Hydro projects totaling 1.7 GW!
- Three Flywheel projects totaling 28.32 MW
- An Ice Thermal Storage project for 25.6 MW
- A Lithium Ion Titanate Battery and a Lithium Nickel Manganese Cobalt Battery project, each 10 MW
- Two Zinc Air projects totaling 13 MW
- Four Li-PO4 projects totaling 4.04 MW
- A Vanadium Redox Flow Battery 2 MW
- Miscellany: Zinc Iron Flow Battery and various Electo-Chemical projects including STEM's 85 MW which appears to be similar to AMS' hybrid buildings and likely Li-ion.
The 3rd search was "announced" projects (
obviously the most tenuous):
Results were 112 projects with total rated power capacity of 5.3 GW.
I downloaded the file and sorted it by size. The largest Li-ion project was No. 13 at 15 MW.
Nine of the eleven biggest were pumped hydro, totaling 4.53 GW.
The other two in the top ten were in-ground compressed air with 317 MW and 300 MW each.
Axion Power made the top 20 with two lead carbon battery projects at 12.5 MW and 9.1 MW.
Those you have convinced that saying energy storage is "a crowded field with lots of competitors and solutions" is an
exaggeration and misleading might benefit from running a few searches on DOE's database site and not just limit them to the USA. Take a look at what's going on in the rest of the world and who all the players are. Tesla's business plan is to leverage its auto sales and service locations to market solar and battery storage products. That may be fine for residential buyers; but utility-scale and behind-the-meter industrial and commercial customers expect well engineered proposals adapted to their individual situations with convincing economics.
