Interesting. Does it also have dash cam recording? I don't see how sentry is available but not dash cam.AP2.0 mcu1 12/2016 delivery. I just received update. And....yes...it has sentry mode. I confirmed and turned on via controls menu!
The manual points you to set up a USB drive referring to the Dashcam procedures. I am not sure on the dashcam functionality. I'll see a bit later.Interesting. Does it also have dash cam recording? I don't see how sentry is available but not dash cam.
75Ds will not be able to get a good bump in supercharging speeds as those cars come with a charger that maxes out at 48A, this is also why it maxes out at ~100kW.
The 100D and P100D max out at 72A.
The real winners are the guys who bought the "dual charger" setup way back when.
That has absolutely nothing to do with supercharging. 48 amps or 72 amps is AC (home charging) and supercharging is DC. "
Is it because of the difference voltages between the 75 & 100 packs?
Great, that's you & rush6410 now with AP2.0/MCU1 getting it, BooyaInstalled 2019.12.1 this morning, from 2019.8.5. Model X 100D AP2.0/MCU1.
Tried a Sentry mode recording, but all files come out as 1k size, no info. Same as before, so the .1 didn't fix that. Sentry does activate though.
My observations is that the car identifies usb drive and may be recording. But, there is no way to remove the usb drive without corrupting it. Us AP2.0 folks do not have the dashcam icon to pause the access to the drive in order to remove. I am getting folders with timestamps of recording activation and get the same 1k file issue you are see. When accessing via PC, it says the drive is corrupted.Installed 2019.12.1 this morning, from 2019.8.5. Model X 100D AP2.0/MCU1.
View attachment 401086 So, I’m out of town, and I just got wise and opened the apps “Controls”, and can also confirm that Sentry Mode is now an option! 75D, AP 2.0, MCU1.
